| Hi All,
 I posted a little over a month ago that I was sometimes getting a huge number of errors right after starting the car (2008 AJV8): transmission fault, HDC fault, suspension fault and many others. Turning the car off and restarting would cure it and the car drives fine.
 I had it in to the indie mechanic who diagnosed a shot alternator and a battery just barely within spec. I had him change out the battery and the alternator was professionally rebuilt.
 Also, given the recommendations I received the first time around here, I make sure to allow everything to "boot up" before attempting to drive off. (I wait for the airbag warning light, the slowest of all the lights that come on when starting, to extinguish before driving.)
 The last two days, I've had the "everything errors" coming back. (To say I'm not happy would be rather an understatement.)
 I've notice two things: first this has only happened when the car has been switched off for very short periods of time (park, run into shop, run out) in the 2-3-4 minute range. I remember there's a busy time after shutdown when you can't disconnect the battery. Could this be having an effect?
 I put the IID on the car. On plugging it in, I noticed the voltage reading (engine off) was 11.8 to 11.9V. I remember getting about 12.2V under similar conditions before the work.  Is this a problem? Bad battery still? Bad alternator still? Is there anything that could stop the battery and alternator doing their jobs?
 Any advice (other than buy a Toyota) much appreciated. And yes, I do have a call in the mechanic for a callback on Monday.
