Home > Technical (L322) > Best choice for Winter tyres - dedicated or MTR?
Page 1 of 3 123>
Tim in Scotland
Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland
2010 Range Rover Vogue TDV8 Stornoway Grey
OK the first snows of winter have been forecast for high ground in Scotland already (not where there are any roads I hasten to add, but that doesn't mean a Range Rover cannot get there! )
I want to clear out at least one set of wheels and tyres from my overstocked tyre store and wonder which is a better winter tyre a specifically designed/ developed Ice and Snow tyre or a Goodyear Wrangler MTR as I have both in the garage - both are 19" and while both were bought for my RRS they will also fit the L322. Problem for me is that the Goodyear MTR can possibly be used as both an offroad tyre AND a winter tyre whereas the Pirelli Ice and Snow Tyre is specifically an on-road winter tyre. The drawback of the MTR as a winter tyre is on-road noise generated by the chunkier tread, extra vibration and the fact that I don't intend to use the FFRR anywhere near where the MTR will be useful. 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes
Post #28453 19th Sep 2010 2:24pm
Well I have just "upgraded" from 20" Pirellis (Road) to 18" General Grabber AT2s for the winter/softer ride. Can't say I noticed much in the way of increased road noise (the diesel sees to that!), wheel wobble at 60mph has gone, on road grip doesn't feel any different wet or dry, and I like the retro look (had these wheels on my P38 Smile)
With all the snow in the south last winter, I had no trouble going anywhere with the Pirellis on (driving through 2/3 ft snow drifts to rescue/bring into work fellow workers) so if we get it again I expect the same and more from the Grabbers... .
Post #28454 19th Sep 2010 2:31pm
Tim in Scotland
What has been the effect of such a drastic size change been on your speedo/ odo or have you managed to work a change that doesn't have any effect on rolling circumference? 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes
Post #28459 19th Sep 2010 2:46pm
Vogue
Vredestein Wintrac 255/55/19 as the name says its a winter / track tyre and the speed rating is fine, I keep them on all year round, good wear rates, theres a huge write up on the D3 forum - runs to about 12 pages - The MTR's speed rating is compromised...
Post #28460 19th Sep 2010 2:50pm
nbunney
United Kingdom 2018 Range Rover Autobiography SDV8 Corris Grey
Tim
If you do not go with the MTR's will you be selling them ? Whistle
Post #28462 19th Sep 2010 3:03pm
Macdaddy
2003 Range Rover Autobiography 4.4 V8 Java Black
Nigel... Just how many sets of wheels and tyres do you need Laughing
Thinking of a winter set myself now tho Idea TDV8 HST Sport **Current**
4.4 V8 Autobiography and 22" wheels **Gone**
Post #28464 19th Sep 2010 4:39pm
davemfox
Glad you posted this as I'm looking to replace mine for this winter too - on 18" rims.
I had a short list of Pirelli, Hankook and Kumho, but now that you've mentioned Vredstein I'll look at them too Smile
Dave 1993 YZF 750 SP
Post #28466 19th Sep 2010 4:53pm
nbunney
Only after the tyres, as I have a few wheels now (4 x 18" Disco2 / 9 x 19" & 2 20" FFRR wheels in the garage)
Post #28503 19th Sep 2010 8:08pm
SteveMFr
Site Sponsor
MTR's are terrible wither tires. Unless, possibly - and only possibly - you are in very deep, very powdery snow. On all other surfaces especially plowed or packed snow even AT's or street tires make better snow tires. The large , chunky blocks in an MT tire find no grip whatsoever. What makes winter tires good are sipes and the rubber formulation designed to keep the tire pliable at very low temperatures.
With all my RR's I've found that it makes most sense to go with all-season tires year round - although I do make a point of checking tests for winter performance when choosing a tire. For very heavy snow on very steep alpine roads I have chains (though I've rarely used them). And then I have my off-road tires. I generally stick with AT's simply because we drive long stretches of hwy between off-roading and MT's are just too loud/uncomfortable/poor performing. I've considered summer/winter/off-road tires but even with floor jacks and air tools it's just too much work to be switching tires every couple weeks (as I have to switch between track and street tires on my Porsche too. + the wifes car...)
You see, Tim, we Americans know quite a bit about cars - including tires and oils. And we also know that generalizations are for the birds. Twisted Evil
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #28525 19th Sep 2010 9:49pm
The car started life on 18" wheels at 255/60 so I should be back where it started, however, (wait to be flamed) my understanding is that the 20" with lower profiles, 255/50 give the same overall circumference. A quick check with the tape measure seems to bear this thinking out. .
Post #28535 19th Sep 2010 11:14pm
Vogue
255/55/19
255/50/20
all have the same rolling radius and are original oem fitment for the L322
RRS has lower aspect ratios at 55, 50 and 45 for 18", 19" and 20" i.e. smaller diameter
Post #28536 19th Sep 2010 11:34pm
I used to run with MTR on my Defender and in the wet on Tarmac they do produce comedy levels of understear and generally felt like you we on ice all the time, best avoided unless you actualy live in the mud most of the time. 2008 MY Supercharged
Post #28540 20th Sep 2010 7:26am
Philip
2019 Range Rover Autobiography SDV8 Aintree Green
How do Wintracs compare to the Scorpion Zero out of the mud and snow?
Post #28557 20th Sep 2010 10:58am
Vogue
very very slightly more noisier - but definitely not much in it - pleasing growl when you gun it. Off road one hell of a difference, the treads don't clog up so readily.
As for handling no difference - still chuck her around tight bends no problems at all - wet or dry. Would buy again! and according to D3 forum expected wear rates are 35k ish miles - Zero's and Good Year I struggle to get 25 out of them. Plus they are very reasonablly priced. Running 7 RR's at the moment so have got good comparisons.
Post #28561 20th Sep 2010 11:18am
Philip
Interesting, thanks. After ~15k, the originals Scorpions don't have a great deal of life in them.
7 RRs? One for each day?
Post #28580 20th Sep 2010 1:21pm
Page 1 of 3 123>
