![]() | Home > Maintenance & Mods (L322) > Yet another Transmission thread...... |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8794 ![]() ![]() ![]() |
When I bought mine back in March it had several declared faults, the main one being a slightly hard first to second change, the seller said he had had the rear main crank seal on the engine done and when he got it back it was doing it, they said that it would get better as the transmission relearned itself.... yeah right, thinks me.... it was still a cheap car even if I had to do the box and the rest was OK....
Mine is the ZF 5HP24 but I guess they won't be a million miles apart...
JST Member Since: 12 Dec 2013 Location: Somerset Posts: 502 ![]() ![]() ![]() |
alot of the ZF boxes in my experience have difficult shifts 1 to 2nd for the first shift of the box in that cycle straight after a fluid change, have a look on the ashcroft site on freq questions part. this would of cleared though in your 7k miles since fluid change.
As I said above I've never had the Trans Heat message, it's always been the Trans Failsafe....
Don't know whats happening with photobucket... I'll try again
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1031 ![]() ![]() |
[quote="Haylands"]
Phil,
Regarding the statement from the garage on learning new adaptions – only long term adaptions are stored in the controller once the ignition is turned off i.e. those that relate to the gradual change in performance of the transmission over thousands of miles - provided the fluid characteristics don’t suddenly change. In other words the controller progressively modulates the clutch pressures to maintain the slip times over the transmission’s lifetime. A sudden change to the new friction characteristics of Dexron (red) fluid could upset this and the adaptions will have a limited range over which they can make corrections.
Phil,
