Home > Technical (L322) > Brand new never discussed before technical issue! (maybe) |
KurtVerbose Member Since: 08 Aug 2010 Location: Les Arses Posts: 5848 |
My brakes are ok (not sh*t, not stunning) - typical TD6 brakes. I notice when reversing they're sh*t. I was backing a loaded trailer down a slope and they required a very big squeeze to stop - much bigger than if I was going forwards.
9th Oct 2014 7:54pm |
GrahamCharlton Member Since: 17 Aug 2014 Location: Newcastle upon Tyne Posts: 30 |
If you were reversing the trailer down a hill the trailers overrun brakes would not operate so the range rover brakes would be trying to stop the weight of the trailer as well as the car. If you were going forward the trailer brakes would operate and assist in slowing the trailer. I don't think there sounds like anything wrong. |
9th Oct 2014 8:02pm |
Ah, come on - can't be that simple. We should have pages and pages of discussion here! |
9th Oct 2014 8:06pm |
You could be right. It might be something to do with the model year of the trailer. Or perhaps it is older than you think and has been face lifted in which case it could be some compatibility issue. I think you had better take it and get it plugged in to the computer for some diagnostics! |
9th Oct 2014 8:15pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3954 |
"My brakes are ok (not sh*t, not stunning) - typical TD6 brakes"
9th Oct 2014 8:17pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 7916 |
Do you have directional tyres I recon it could be that
9th Oct 2014 8:23pm |
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3697 |
Try disconnecting the battery and waiting 20 mins... Previously..
9th Oct 2014 8:35pm |
I'm going to try disconnecting the trailer and trying. |
9th Oct 2014 8:41pm |
sako243 Member Since: 26 Dec 2013 Location: Wales Posts: 605 |
Shouldn't affect braking performance but they are usually designed to have the wheels rotating forwards as that is usually what they do. It is theoretically possible to twist them off if reversing really fast (probably faster than the vehicle's capable of in reverse). |
9th Oct 2014 8:49pm |
+1 for the overrun brakes on the trailer not working in reverse. Same with my caravan, takes more braking force if the trailer is trying to pull you down the hill..... There is nothing that can't be fixed with a hammer๐๐
9th Oct 2014 9:02pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6399 |
Certainly used to get this with "proper" Minis and MG Midget Mk1 (both drums all round) without trailers (of course) in reverse. so guess the same physics may apply ? Not noticed it on my FFRR though (without trailer). .
9th Oct 2014 9:30pm |
RR2008HSE Member Since: 06 Jan 2013 Location: British Columbia Posts: 2932 |
Yes, Joe.
10th Oct 2014 2:16am |
Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1898 |
Mick this is the problem, stop over loading the trailer and the brakes will work If it dont work.......burn it! If the IId tool cant fix it.......burn the FF. If the FF cant be fixed......buy a Land Cruiser! If the LC cant be fixed..............................................BUY a horse !! |
10th Oct 2014 8:21am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34933 |
who's mick? ... - .- -.
10th Oct 2014 9:08am |
