![]() | Home > Technical (L322) > Turbo squeal STILL. Help save my RR because I'm done :( |
cowman Member Since: 24 Jul 2013 Location: United Kingdom Posts: 186 ![]() ![]() ![]() |
finally got to the bottom of this and found out the problem exhaust manifold leaking ,took it in to my local indi and they have stripped it and sent the manifold of to be machined ,hope it solves the problem. |
Just as an outside thought, the crankcase breather. Have you fitted the newer version at all?
yes i have fitted the later crancase filter ,havent got it back yet from indie |
That's good as that's been known to cause turbo failure. FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
got mine back from garage all fixed did the manifold changed both belts ,400 pounds,bargain i thought it takes 6.9 hrs to change exhaust manifold gaskets,also changed the down pipe if yours has got a aftermarket one one ,it makes a zinging noise up the rev range as though you have got a leak . |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7993 ![]() ![]() ![]() |
That's exellent news. You won't have to worry about that issue again.....
