![]() | Home > General > Water in the Boot |
| Macdaddy Member Since: 15 Oct 2009 Location: Preston, Lancashire Posts: 466
A common place for leaking on that side.
| hongkongphooey Member Since: 27 Aug 2010 Location: Douglas. Posts: 227
A good idea. I'll get some thin fuse wire and check the drain holes and maybe some silicone rubber lube (oo er), see if that helps.
| delamo Member Since: 17 Mar 2010 Location: Beaconsfield, Bucks Posts: 1121
hongkongphooey - now you have had the dreaded water in the boot problem, Can I suggest a couple of things to do?...
Hi Delamo,
Found it |
