![]() | Home > In Car Electronics (L322) > Urgent help with GPS please, unable to reset arrow |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8768 ![]() ![]() ![]() |
Does it keep pointing east when you drive, I find mine can be a bit errant on its initial direction assesment until you start moving, it then sorts itself out when it sees whch way the car is heading. There is nothing that can't be fixed with a hammer😜😜
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1852 ![]() ![]() |
As above. After half a mile or so, it should get an accurate position/direction.
Its probably a faulty GPS Arial/Receiver they are prone to water damage. I have had a few need replacing in Jags mostly but a few RR. Easy job. |
What gaz said if it has no idea where it is, but if it has got the correct location and it's just pointing in the wrong direction....... There is nothing that can't be fixed with a hammer😜😜
Is the car pointing east ? are you in head up or north up mode ? 2008 MY Supercharged
verydisco Member Since: 10 Dec 2009 Location: UK/US Posts: 2952 ![]() ![]() ![]() |
Guys, sound Gaz nailed it as the car had a water damage after Land Rover dealership installed the snorkel and pinched the sunroof drain pipe.
Its normally the Arial itself located on the Roof.....
Thanks, will check the aerial and the wiring.
Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1528 ![]() ![]() |
not a problem to work on roof aerial with the lining in. just remove the clips for the dog guard and there is a plastic clamp a few inches into the roof from the rear in the centre. |
thanks |
