Home > Maintenance & Mods (L322) > Engine blower running all the time?
Strange one this. Drive a few miles this morning, all was well. Stopped for a few minutes and when the car was restarted the heater was blowing hot air. No amount of temp adjustments made any difference.
If I turn all the heater controls to off, a blower under the bonnet keeps running. Tried disconnecting the battery for an hour or so but when I reconnect the blower starts up again. Under the bonnet is very hot, but the temp gauge is showing normal.
IIDTool shows this error - p0480-13(2f) fan control circuit, but that's as much as I can find.
Anybody got any ideas?
Ive left the bonnet open to see if the temp will drop far enough to allow if to stop,assuming that's why it's on Got - 2017 SDV8 Autobiography in Loire Blue
Post #286038 12th Oct 2014 3:57pm
Mikey
Have seen wires damaged at the viscous van hub, causing the fan to run on all time
Also seen a few AC issues, pressure too.high, so the fan comes on to bring the temps and.pressures down
Post #286048 12th Oct 2014 4:34pm
try pulling the fuse for a bit alan.. ... - .- -.
Post #286049 12th Oct 2014 4:36pm
Which one Stan? I can't see a number that refers to the engine fan Whistle Got - 2017 SDV8 Autobiography in Loire Blue
Post #286053 12th Oct 2014 4:48pm
Is this the HVAC fan or the engine/radiator electric fan that keeps running? - if the former could be FSR related? .
Post #286069 12th Oct 2014 6:06pm
It seems to coming from the big blower unit at the back of the engine bay, closest to the windscreen. It's not the fan at the front, and it vents out of the bonnet grill.
Do later cars still use a FSR?
If it is the FSR, can I pull a fuse to stop it flattening the battery and still be able to use the car? Got - 2017 SDV8 Autobiography in Loire Blue
Post #286071 12th Oct 2014 6:10pm
Mikey
The interior blower still uses an FSR Thumbs Up
Post #286090 12th Oct 2014 7:06pm
Can I pull a fuse to test and stop it flattening the battery? Got - 2017 SDV8 Autobiography in Loire Blue
Post #286093 12th Oct 2014 7:12pm
i think its fuse 34 but not 100%... ... - .- -.
Post #286103 12th Oct 2014 7:22pm
OK, its not engine related by the sound of things, either HVAC (in which case I reckon FSR) or possibly even FBH on the go?
Used too many acronyms in one sentence, so have to go and take my medicine Laughing .
Post #286184 13th Oct 2014 12:05am
Put the battery on charge last night and had a quick go at pulling out fuses 12 & 34, which I believe are both A/C related. Blowers still comes on as soon as the battery is connected.
My first thoughts yesterday were the FBH,so when I got home I tried turning it off with the remote. Made no difference but the remote seemed to be talking to the car ok.
I'm guessing fuse 59 is the FBH?
Anyway, off to Aberdeen on the train soon, so I'll pull the FBH fuse later and see if that makes a difference. Got - 2017 SDV8 Autobiography in Loire Blue
Post #286188 13th Oct 2014 6:05am
Got home tonight. Tried fuse 59, same problem.
Tried all and any any fuse that is related to a/c, no change.
Thing is, now I can't turn the a/c on, nor the hrw or hws. I'm totally stumped! Got - 2017 SDV8 Autobiography in Loire Blue
Post #286324 13th Oct 2014 7:43pm
Just a quick update to say the problem was indeed the FSR.
All replaced and all is well, so many thanks to all those who advised this was the likely cause. Thumbs Up Got - 2017 SDV8 Autobiography in Loire Blue
Post #286448 14th Oct 2014 7:01pm
Googsy
Thumbs Up Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #286468 14th Oct 2014 9:10pm
Very Happy Thumbs Up .
Post #286488 14th Oct 2014 11:48pm
