Home > Technical (L322) > FBH Remote/ Receiver problem?
J evro
England 2008 Range Rover Vogue SE TDV8 Stornoway Grey
Ah, I have that same problem,....
Post #284409 4th Oct 2014 6:52pm
Andy_J
Scotland 2007 Range Rover Vogue SE TDV8 Java Black
Now programmed the T91 transmitter I bought from e-bay and problem now fixed. Can turn the FBH on from inside the house now Very Happy so no cold RR in the morning 56 TDV8 Vogue SE
9 Freelanders, 2x 2002 TD4ES, 2001 TD4, 2002 1.8GS, 2000 XEDI, 2x 2000 1.8ES, 2004 1.8 & 2000 1.8 GS (rolled)
91 Lotus Carlton (sold)
90 Lotus Elan (BRG)
Post #286125 12th Oct 2014 8:09pm
J evro
Good news Thumbs Up
Which reprogram sequence did you follow?
Post #286142 12th Oct 2014 9:16pm
taskam
Result Thumbs Up 2007 TDV8 Vogue SE Java Black
Post #286164 12th Oct 2014 9:56pm
Andy_J
J Evro - I used the method described by Paulmoran2 in your tread
http://www.fullfatrr.com/forum/topic27290.html?highlight=t91
In my case it seems that the fob was not transmitting although the lights on my broken fob flashed 6/7 times when the buttons were pressed. You could have the same problem as me. My old unit was a T90 and worked until February this year, then just stopped transmitting. Think it only cost £35 for the replacement t91 56 TDV8 Vogue SE
90 Lotus Elan (BRG)
Post #286167 12th Oct 2014 10:10pm
J evro
Ok ta,
Must be something else with mine as said previously I've tried the paring as per Pauls instructions- no joy...bought another fob - paired - no joy..tried it on screen timer comes on for a couple of minutes then goes off ( no heat), I tried to explain this to the garage who supplied the RR but they say they have checked with LR and they say it will not work unless 6degrees or below as this is what they are set at from factory?...can anyone confirm this ...(they say they cannot set up a 6 degree ambient temperature to test it)
Although it says 16 degrees in the handbook.. Rolling Eyes
Is anyone using theirs now and getting heat and it's above the 6 degrees?
Post #286274 13th Oct 2014 3:59pm
Andy_J
sounds like it is the actual FBH in your case.
Mine fired up yesterday off the fob and it was 10 degrees, also fired it up last week from the touch screen to check the FBH was working before I bought the new remote.
Think the 6 degrees is when it fires up to help warm the engine on cold mornings.
Maybe worth a chat or inspection by your local LR stealer, then you can go back to the garage who supplied your RR with something in writing from LR saying there is a problem 56 TDV8 Vogue SE
90 Lotus Elan (BRG)
Post #286315 13th Oct 2014 7:05pm
