Home > In Car Electronics (L322) > Reversing Camera Pal Or NTSC?
Av_dave
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
I wonder if someone could shed some light on this there's a friend of mine who is replacing his reversing camera. He has fitted one but its in black and white so asked me to have a look he assures me its a pal camera as this was the first question I asked and on the box it does say pal. But by it appearing in black and white it would appear it's ntsc and when I go into the hidden menu on the touchscreen stereo and switch the test mode to ntsc it displays perfect picture in colour. Am I correct in thinking if was the other way round ie a ntsc head unit and pal camera nothing would display at all?
It's a 2005 touchscreen Ffrr
Thanks in advance. [/u] The difference between theory and reality is that in theory it will work.
Post #286635 15th Oct 2014 5:47pm
Welshdragon
Wales 2003 Range Rover Vogue 4.4 V8 Monte Carlo Blue
funny that, my 03 shows PAL and NTSC on the screen settings for the tv, my camera supports both..... but only works on NTSC Thumbs Up If it dont work.......burn it!
If the IId tool cant fix it.......burn the FF.
If the FF cant be fixed......buy a Land Cruiser!
If the LC cant be fixed..............................................BUY a horse !!
Post #286639 15th Oct 2014 5:56pm
Av_dave
Yer it's weird I can't find a way of forcing it to stay in ntsc mode I'm guessing it can't be done on touch screen cars?
Thanks The difference between theory and reality is that in theory it will work.
Post #286641 15th Oct 2014 6:00pm
adara
Romania 2019 Range Rover Vogue 2.0 PHEV Santorini Black
It's definitely NTSC as I tested the connections with a PAL home surveillance camera and the image was B/W...
Post #286801 16th Oct 2014 10:46am
Av_dave
Thanks adara, does this mean that the touchscreen cars need a ntsc camera or is it just the earlier none touch screen ones that are ntsc?
Post #286803 16th Oct 2014 10:50am
adara
Mine is touchscreen and it still needs NTSC. But it's easy to test through the 753 secret menu...
Post #286836 16th Oct 2014 2:10pm
Av_dave
I've done the test through the 753 menu. He has ordered another camera in ntsc format. Will let you know how we get on fitting it over the weekend.
Thanks Again The difference between theory and reality is that in theory it will work.
Post #287039 17th Oct 2014 12:18pm
hex
United Kingdom 2002 Range Rover HSE Td6 Baltic Blue
The reverse cam is opposite to what the TV input is , this is to stop you feeding TV in to the screen while in motion using the reverse cam input
Razz
Post #287198 17th Oct 2014 10:22pm
Av_dave
Thanks for all the input. Problem solved and a ntsc camera has been fitted and is now working. Just to let anyone else know that needs to swap there's. The difference between theory and reality is that in theory it will work.
Post #287575 19th Oct 2014 6:43pm
