![]() | Home > In Car Electronics (L322) > No beeps from rar of car when caravan attached |
| philmc79 Member Since: 10 Sep 2013 Location: Hyde Cheshire Posts: 94
I have changed the wiring from a 7 pin socket to a 13pin euro plug using a proper wiring loom from Land Rover and removing a generic wiring loom since doing this there is no beeping when the indicators are activated as it did on the generic loom, is this correct or have i missed something on the installation on the proper loom?
| paulmoran2 Member Since: 27 Nov 2013 Location: Leeds Posts: 1422
I have standard 7 pin OEM electrics on my 2007 and there's never been a beep on indication... |
Thanks for that i was just checking i think the old one prob did it as a confidence thing as the car does the checking for you.
| mzplcg Member Since: 26 May 2010 Location: Warwickshire. England. The Commonwealth. Posts: 4029
Aftermarket looms often contain a buzzer whereas the factory one does not. As long as you have the green trace light on the dash everything's OK |
| mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 8002
As others have said, you don't get the beeping as you have the telltale on the dash. The proper way that it should work. |
| miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3669
Tell tail on the dash????????
| kingpleb Member Since: 07 Jun 2011 Location: Maybe here. Maybe there, I get everywhere! Posts: 8455
It all depends on how your trailer setup is set in the ccf.
I don't get the trailer light, and having read the destructions there is no reference to the little green trailer, I will have to delve deeper into this. It does every thing that is listed, and I've had no problems, I wonder if its a plug'n'play thing, and the light gets enabled at the stealers. Did you have yours programed at the stealers or is it a plug'n'play? Yesterday I couldn't spell Engineer... Today I are one!
Mine, like most, was plug and play as I got the twbar a good two years before I got my faultmate. FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Sorry if I made things more confusing Paul, I don't think our early cars have the green tell tale, its the later ones I believe, like philmc79 has.
Does that mean that I should stop looking for it? |
| Swiftman Member Since: 23 Jan 2013 Location: Midlothian Posts: 128
Hi on 2006 model. There is a green light in dash panel that comes on when you plug trailer in just stays on to let you know trailer plug is attached. Earlier car the light flashed with indicators . Cars have. Landrover wiring kit fitted |
| All times are GMT |
