Home > Technical (L322) > Brembos?
otto-mate
Northern Ireland
Brembos?
Can anyone tell me when the brembos were available? Did they stop for a while them bring back?
Thanks
Post #286830 16th Oct 2014 1:27pm
pld118
otto-mate,
Do you know how to update your profile so viewers know what variant and year L322 you have (makes it easier for replies) to be tailored to your car Thumbs Up
It has previously been posted on the forum that LR stopped fitting Brembo's on 09/10MY cars and that they started fitting them again in 2010.
Post #286837 16th Oct 2014 2:10pm
otto-mate
Northern Ireland
Thanks pld118. I've just sold my X5 and I'm in the research/looking phase at the moment, my profile is set to 'not an owner'.
Post #286838 16th Oct 2014 2:13pm
pld118
Bow down
Post #286850 16th Oct 2014 3:02pm
Advanced Factors
Site Sponsor
Have a look through the braking section of my website, you will find the info you are looking for by model year/engine type
http://www.advancedfactors.co.uk/brake-par...r-51-c.asp Paul Redding
+44 (0)23 8052 2760
paul@advancedfactors.co.uk
Post #286852 16th Oct 2014 3:09pm
Mikey
Brembo's were available on all SC models from 2006, and all TDV8s from 2007
Not sure if they were discontinued at the end of the 09 production run, but fitted again on 2010 models.
At some.point they also fitted 6 pot Brembo calipers
Post #286943 16th Oct 2014 9:25pm
They were fitted to all 2006 -> 2009 cars, 4.2sc and tdv8. They were discontinued on the 2010 facelift year 3.6tdv8's but continued on the s/c and were reintroduced to the diesels with the 4.4tdv8 which have the 6 pot calipers. I think the 5.0sc has the 6 pots too but not sure when they were introduced though I suspect at 2010 facelift. There is nothing that can't be fixed with a hammer😜😜
Post #286945 16th Oct 2014 9:29pm
As above but for clarity, the 2009 3.6 TDV8 facelift was when they ditched the Brembo's and then re-introduced them (in 6 pot guise) on the 2011 4.4 TDV8 Thumbs Up Thumbs Up Thumbs Up
Post #286972 16th Oct 2014 10:54pm
That's what I meant... Whistle facelift model so effectively 59 plate > Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #286974 16th Oct 2014 10:59pm
Post #286975 16th Oct 2014 11:00pm
sasdiscos
United Kingdom 2010 Range Rover Vogue SE TDV8 Zambezi Silver
I fitted brembos to my disco and it was much better, ive brought a ffrr on the change over plate 59.
No brembos, but i might fit them, does any one know if both types will fit, 4 pot or 6 pot? and also, what are the standard discs and pads, tdv6 part number? or were there separate parts just for the interim?
Cheers, Steve
Post #287015 17th Oct 2014 8:55am
I have not checked but... 4 pot Brembos have a smaller mounting bolt than the 6 pots so, NO you cannot put the 6 pot on a 4 pot hub (if that makes sense?) so, you would need to check the size/diameter of the mounting bolt hole through the hub on your car to tell if it would take the earlier 4 pot of later/larger 6 pots Thumbs Up Thumbs Up
TDV6 part numbers??????? No such FF on a 59 plate sir...
Post #287020 17th Oct 2014 9:48am
sasdiscos
Thanks, i just meant that if all the pre 2009 had brembos, and then for 1 year they stopped and then started again after 2010, was there and interim part number for the brakes, or were there earlier tdv8s without brembos?
Forgive my stupidity
Steve
Post #287072 17th Oct 2014 2:53pm
nobbyclark
Why did they ditch the Brembo brakes on the 3.6 TDV8? Cost? Reliability? Something else? My TDV8 obviously has non-Brembo brakes as it was built in Jan 2010, but it could certainly do with them as whatever it is fitted with are not really up to the job.
Post #287689 20th Oct 2014 11:19am
could have been a cost or supply problem.. ... - .- -.
Post #287692 20th Oct 2014 11:39am
