Home > Technical (L322) > Whole centre console not working! Smell of burning ...
andrew-a
Last week out of the blue the ventilation stopped working -no lights on the console, no heated seats or AC. Basically the whole upper section of the centre console was dead. Tonight, the lower section of the console is dead as we'll , including the air suspension. Even the orange gear selector indicator doesn't light up! And to top it all up, I can smell something has been burning behind the dash. Any ideas? Apart from that, the car drives, stops as normal. All other electrics work.
Post #287214 17th Oct 2014 11:24pm
please update your car profile so we know what you have... ... - .- -.
Post #287215 17th Oct 2014 11:25pm
andrew-a
2003 4.4 petrol
Post #287217 17th Oct 2014 11:30pm
crispy2
Australia 2007 Range Rover Supercharged 4.2 SC V8 Zermatt Silver
Andrew, what Stan means is to edit your profile in settings so the footer of your posts shows what you have for a Fatty.
Post #287226 18th Oct 2014 1:33am
andrew-a
I have updated it, but it doesn't show -nothing seems to be working at present and it's just not the car! Big Cry Big Cry
Post #287243 18th Oct 2014 8:58am
mjdronfield
It's pretty easy to have a look behind the panel. There is a single screw on the side panel in the footwell, and then the wooden bits at the side of the switches clip off sideways.
You need to look for damage if you have been smelling something burning.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #287255 18th Oct 2014 9:58am
100% get the AA/RAC to recover it to a professional before you turn into a statistic my friend...I personally would not drive it one more inch before resolving the problem... Bow down
Post #287258 18th Oct 2014 10:04am
What could possibly go wrong Craig?
Post #287271 18th Oct 2014 11:13am
andrew-a
Thanks guys. I have removed the ventilation facia and the main wire loom connector (it's blue on my car) has burnt out, but seems to have welded onto the panel. Everything else works, even the rear blower. So what's the damage and how much? It will need some loom, the blue connector and maybe the motherboard on to which it attaches as that may have been burnt as we'll
Post #287277 18th Oct 2014 11:19am
You can't just replace them without finding the source of the overload sir... Else you will just burn out the next plug & potentially more next time around...
Craig
Post #287281 18th Oct 2014 11:29am
andrew-a
Yes I agree. Just need to fully disconnect it now to ensure that it doesn't cause further problems but I can't get the main loom off as it's welded to panel. Which connection transfers the power to the unit - does anyone have a photo or diagram? Thanks
Post #287304 18th Oct 2014 12:20pm
