![]() | Home > Technical (L322) > IIDTool from gap diagnostics ***Q & A *** |
Katash Member Since: 10 Apr 2011 Location: Hereford Posts: 700 ![]() ![]() ![]() |
Your parking brake is on, turn it off. |
Brilliant, thanks very much Katash. Sorted now!
RR2008HSE Member Since: 06 Jan 2013 Location: British Columbia Posts: 2932 ![]() ![]() ![]() |
Katsh, you beat me to it!
jerrytlr Member Since: 02 Apr 2013 Location: France Posts: 66 ![]() ![]() ![]() |
Hi - apologies if this is already covered in the thread, haven't really got time to read it all!
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3270 ![]() ![]() ![]() |
"If not, and I need to step up to the bluetooth version, does that give the same functionality from the connected device (I have an ipad I can use) as you get from the built in display/cruise control buttons?"
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1858 ![]() ![]() |
Bluetooth version, every time |
Short answer: yes. But the USB / Laptop interface is much less convenient to use. And, the big difference between the IIDTool and the IIDTool BT is that he IIDTool BT has much more memory, meaning that we can upload the firmware for all Land Rover models we cover to one tool - in effect the VIN-lock-free functionality giving you the equivalent of a Hawkeye Pro or Lynx Pro at 1/3 the price. The regular non-BT IIDTool only has enough memory for one model line - so the VIN-lock-free functions are only avail for that model (2002-04 L322 or 06-09 or D3 or D4, etc). HTH Steve ![]() RRC 2Dr, RRC 4Dr, P38, and 2 L322s (wife thinks I'm nuts - prob right, too) |
sasdiscos Member Since: 16 Oct 2014 Location: Northants Posts: 286 ![]() ![]() ![]() |
Steve, quick one, just got my iid. bt
FBH is named Auxiliary Heater. Are you checking for the right module?
Should be in the CCF.
Merry crimbles,
Shogo Member Since: 01 Jan 2015 Location: Sweden Posts: 61 ![]() ![]() ![]() |
Hello!
JackRegan Member Since: 20 Oct 2012 Location: Wirral Posts: 258 ![]() ![]() |
Quick question, does the updater work with Windows 10?
Eirik34 Member Since: 16 Dec 2014 Location: Norway Posts: 443 ![]() ![]() |
Hi Jack, I’ve only used the updater on a Win7 PC – I would guess that it should work on Win 10 as well. Most Win7 or 8 applications should work fine on Win 10.
