![]() | Home > Technical (L322) > Side Lights / DRLS |
I remember another post about this. I would also love to do it but I believe the headlights also come on when DRL is activated. MY 2010 5.0 SC Galway green and sand interior!!
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16369 ![]() ![]() ![]() |
There are only two market places in the world that need DRL's one uses the headlamps and the other uses the inner halogen full beam at 40% brightness... So, the short answer is NO it cannot get switched on in the CCF files... Only wired using a relay, but then they will only be as bright as side lights so what would be the point? |
Ajay(UK) Member Since: 02 Mar 2010 Location: Arundel, W. Sussex Posts: 608 ![]() ![]() ![]() |
Chris, if you can get yourself over to Arundel at some point I can sort this for you |
Thanks mate, good to know that I can do it on my 5.0 as well |
