![]() | Home > Technical (L322) > Service required and low battery |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3926 ![]() ![]() ![]() |
My new car flashes up "service required" for a second or two when I start it, I have reset the Service Counter with the IDTool but no change. Should I be worried or is it normal behaviour.
Actually that was what I was hoping someone might say, would be good to get it confirmed (or otherwise) from someone with a similar vehicle |
CSK Member Since: 15 Oct 2010 Location: St Tropez Posts: 750 ![]() ![]() ![]() |
Mine L322 5.0L SC didn't have the low battery message on start up. When it says low battery you do have a low battery. I know there's an update your dealer should do and also a later model larger capacity battery. |
I think there have been one or two updates to the BMS since your car rolled off the line, might be worth checking it out. The iid tool can do flash updates now can't it? Also is your car not fitted with an agm battery? FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
I had no low battery messages on my 5.0 SC so you may have an issue that the battery is actually low/dying. It would be good to get the total alternator output checked (so also current) and have current drain checked to see if that is within limits. MY 2010 5.0 SC Galway green and sand interior!!
Geoff I have a new Varta in the garage if you want to pop down and give it a try sometime this week? FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
