![]() | Home > Technical (L322) > loss of power / hesitation 3.6 TDV8 |
paulmoran2 Member Since: 27 Nov 2013 Location: Leeds Posts: 1422 ![]() ![]() ![]() |
Good evening gents.
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1870 ![]() ![]() |
P023D
Cheers Mikey....could it also potentially be related to the EGR's as I know they can be an issue?
If it was an EGR issue, it would have logged an EGR code too |
Sounds positive...fingers crossed for a split hose then...will post the outcome
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8784 ![]() ![]() ![]() |
Check both top inter cooler hoses, common problem. Happened to mine, have a look in the wiki I did a write up on how to swap one (logical and easy really). There is nothing that can't be fixed with a hammer😜😜
Found it....a 2" split in the right hand Turbo hose!
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6837 ![]() ![]() ![]() |
Result! |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35852 ![]() ![]() |
nice bit of 'first aid' there.. |
That's the monkey! Should hold fine until the replacement arrives. |
Cheers for the write up NMJ |
Result |
Cheers for the heads-up Mikey...Do you have a list of fault codes we can publish or a link we can post for future use??
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8818 ![]() ![]() ![]() |
Nice cheap fix Paul, wonder how long it would last if you just left it????
