Home > Technical (L322) > injector fault
littlecub
Australia 2003 Range Rover HSE Td6 Epsom Green
injector fault
Just ran my IID tool over the car and one of the faults was 0x56 injector fault.
It was in the IPC (instrument) section.
Is that something that I should investigate further.
Car seems to be running fine.
cheers
littlecub
Post #287233 18th Oct 2014 2:39am
Ziggy
Australia
Dam My Hide I have just done the same thing and come back to the forum to find out and Censored me you have the same fault.......
Cars running OK so I just cleared mine and will check it in a couple of days if you find any other info post it up
would be interesting to compare notes what part of Sydney you in...............were out past Camden S west
Ziggy "Those who cannot remember the past are condemned to repeat it."
George Santayana
Puts away his cloth cap and donkey jacket
Goes and sits in the naughty corner
Post #287238 18th Oct 2014 7:26am
Put a little injector cleaner in at the next fuel stop - normally works a treat.
Post #287245 18th Oct 2014 9:03am
littlecub
Hi Gary,
Will do and see what pops up next week.
Ziggy, I'm at Castlereagh.
littlecub(Gazza)
Post #287247 18th Oct 2014 9:21am
If that doesn't sort it, do a leak test to find faulty injector and replace, fairly straight forward (see wiki). Could possibly be fuel rail wiring loom which also tends to fail. .
Post #287305 18th Oct 2014 12:25pm
littlecub
Thanks joe90,
Am hoping it just needs a bit of a clean.Time will tell tho.
cheers
Post #287461 19th Oct 2014 2:29am
Ziggy
Australia
littlecub wrote:
Hi Gary,
littlecub(Gazza)
G'day Gazza your about an hour away from us down the Northern Road, I worked out of Richmond RAAF base for a bit a couple of years ago........
Back to the injector fault, I replaced the turbo just before I went to the UK and while they were out I had the injectors tested and they all came up well within specs so I'm sure there ok I'll look at the wiring next service
George Santayana
Post #287465 19th Oct 2014 6:40am
