Home > In Car Electronics (L322) > Radio/CD stopped working and wont turn on.
Bagus
United Kingdom 2016 Range Rover Autobiography 5.0 SC V8 Loire Blue
Got in the car today to find the stereo wasn`t working. I had turned it off the other week and today was the first time I turned it on.
The CD and radio were working perfectly before turning it off now it wont turn back on. It seems none of the buttons on the LH side of the head unit work. The OBC and sat nav still work fine.
Plugged in Allcoms but didn`t come up with anything.
Any thoughts on where to start, does it sound like a fuse?
Post #287579 19th Oct 2014 6:52pm
Ianmaney
United Kingdom 2011 Range Rover Vogue SE TDV8 Mariana Black
This happened to me a few weeks ago, i unplugged the 3 plugs on the amp and plugged them back in and it all burst back into life ????
Post #287626 19th Oct 2014 9:32pm
Bagus
Had a flat battery today so went off and bought a new Bosch 020.
Good news: the radio is now back working.
Bad news: I`m getting air Suspension message on the dash and the ABS warning light is on.
6 months in and I`m now experiencing the quirkiness of the RR electronics.
Rather annoyingly I`ve just swapped my work laptop over and removed my Allcoms software. New laptop is program install protected so will need to dig out our old home laptop and install Allcoms on that.
Hopefully it just requires a reset of the error messages.
Rather strange that it happened after battery went flat I thought, no?
Post #288736 24th Oct 2014 10:18pm
after fitting the battery did you set the steering parameters.. ... - .- -.
Post #288737 24th Oct 2014 10:20pm
Bagus
Arhh good point stan. Is that the old turn steering wheel full lock and back trick?
Totally forgot about doing that. Will try in the morning.
Thanks for the quick response.
Post #288740 24th Oct 2014 10:22pm
after a battery re-connect , turn steering fully left then fully right.. Thumbs Up ... - .- -.
Post #288741 24th Oct 2014 10:24pm
Bagus
Nice to have a simple solution for once. I can sleep easy tonight.
Cheers
Post #288742 24th Oct 2014 10:27pm
Geo2toy
United Kingdom 2011 Range Rover Vogue SE TDV8 Java Black
Radio not working
Hi Guys
I have this problem with the radio now as well and I have removed the plugs cleaned with terminal cleaner and put them back on and still nothing!
OBC works as is sat nave and screen also showing the DSP graphics but no sound and on off switch is doing nothing as are all the buttons on the left of the screen.
Was going to go for android but has way more on it than I need so would like to get existing system sorted out and a bluetooth set up added for phone.
Any ideas as to the problem.
Post #300580 23rd Dec 2014 12:56pm
Lyndasbottom
United Kingdom 2002 Range Rover Vogue 4.4 V8 Bonatti Grey
Probably the BM54 pre-amp gone. This feeds into the DSP which relies on a signal from the radio. Try putting a 9V battery across across one of the speaker wires. This will prove the speakers works. If you get some noise the speakers are working which will support the pre-amp theory
Post #300795 24th Dec 2014 8:54pm
