Home > Wheels & Tyres > Fitting wheels
Page 3 of 11 <123 4 ... 91011>
paulmoran2
England 2013 Range Rover Vogue SDV8 Mariana Black
Wheel Hanger AKA Wheel Fitment Alignment tool ordered...£29 from the good ole' U S of A
Will report back on how useless or otherwise it turns out to be GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
HAVE 1999 Discovery 2 GS 4.0 V8 - Silver - Off Road Toy
GONE 2013 L405 4.4 SDV8 Vogue. Black with Silver roofline and 22" s
HAVE 2015 Jaguar XF.
Post #287163 17th Oct 2014 6:25pm
pld118
Just watched the YouTube video and that is a brilliant idea.
However, he did look like he'd benefit from placing a gardening kneeling mat under the wheel to help him more easily slide that heavy wheel onto the hangers Laughing
Post #287176 17th Oct 2014 8:02pm
quabba
Scotland 2005 Range Rover Autobiography 4.4 V8 Java Black
I've ordered this
http://www.ebay.co.uk/itm/Car-Alloy-Wheel-...4d2558f114
not sure if the rod will be long enough but for the price worth a try
Post #287690 20th Oct 2014 10:32am
mjdronfield
Yes, I saw lots of listings for that company but was not aware of the exact thread needed.
That said, my car has bolts coming out of the hub, so from the look of these, they would be unsuitable as you would need a female end to go on hub bolt.
Could be wrong of course...... Keep us posted.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #287694 20th Oct 2014 10:39am
i thought the same as these do look like male and not female as is required.. ... - .- -.
Post #287695 20th Oct 2014 10:43am
Weegie
Would welding rods onto a couple of spare wheel nuts not work just as well? John
GAP iiD BT-Sold
Post #287696 20th Oct 2014 10:46am
you'd have to grind your nuts down so that the wheel hole will fit.. ... - .- -.
Post #287697 20th Oct 2014 10:48am
mjdronfield
Yes, whatever is on the hub side would have to pass back through the hole in the wheel, or you'd never get it off without taking the wheel off again after you've aligned it.
Just a female sleeve long enough would do, but you'd need to have the inner side threaded to suit the stud.
In fact, thinking about it, you could just use a bit of tube so long as it went through the hole in the alloy and over the stud on the hub. You'd have to be careful not to damage the stud thread or leave the wheel on it for too long, as it wouldn't be attached to the car, but it would act as a guide whilst you got a wheel nut on....... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #287703 20th Oct 2014 11:10am
Stephen.125
2017 Range Rover SVAutobiography 5.0 SC V8 Indus Silver
https://www.spaldingfasteners.co.uk/catego...agon-bolts
would the 140mm one of those do, with the head cut off and filed smooth/rounded?
Post #287729 20th Oct 2014 2:24pm
mjdronfield
I might be missing something here then.....
So..... What would you do with it once you've cut the head off ?
You would still be left with a bolt stud and a bolt stud on the hub. You will still need a female tube of some sort.
The car has a bolt stud on it. I imagine the goal here is to artificially and temporarily make the stud on the car longer so you can drop the wheel on it easier.....
I recon we need the inside of a female tube with that thread, not the bolt stud. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #287731 20th Oct 2014 2:33pm
the FF has studs coming out of the hub so no bolt type thingy will work.. ... - .- -.
Post #287733 20th Oct 2014 2:33pm
paulmoran2
I got the ones shown in the YouTube video from the manufacturer but via eBay ( item code eBay Item No. 400776075158) GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
Post #287773 20th Oct 2014 8:11pm
mjdronfield
That's the proper tool.
In the listing, you can see that it has a female end that's threaded to go over the stud in the hub.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #287786 20th Oct 2014 8:34pm
paulmoran2
I'll post the specs when they arrives so that you engineering boys can have a fettle on your home lathes Thumbs Up
Mmmm....what commission rate shall we say?
Laughing GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
Post #287790 20th Oct 2014 8:47pm
pld118
If I'm reading this right, I'm getting a pair of the ones PM2 has ordered for £13 odd... To compliment my kneeling mat Wink
Post #287791 20th Oct 2014 8:53pm
