Home > Technical (L322) > Range rover l322 Air Suspension
Needs to be longer to make it go higher Jo, but not by much for 50mm, if you disconnect one end you can place the sensor a bit higher, then open and close a door to get it to settle and just keep trying till it's where you want it, then make/modify the one on there, to the right length.... Pete
-Click here for Thread-
Post #287788 20th Oct 2014 8:41pm
