Home > Maintenance & Mods (L322) > Fixed - HVAC Air quality sensor line fault
Page 1 of 3 123>
pld118
Hi, the IID tool shows this ECU fault:
"HVAC-Heat / Cool 1/1 0x30 Air quality sensor line fault"
I tried to clear the fault with the IID tool but the fault remains.
I think I've checked all of the hot and cold heater vents both on the seats and elsewhere in the car and they all seem to be working fine (maybe the driver's seat back is a tad less prominent than the driver's seat base but from previous posts, that does not seem uncommon).
An internet search has found references on rangerovers.net to "0x30 0x0030 Air quality sensor line fault" being attributed to an air pollution sensor at the top RHS of the radiator.
I have yet to check fuse 12 (air con) but the fact that the system generally seems to be working would seem to negate a fuse as a culprit.
From the internet search, suggested causes of similar fault:
"0x30 0x0030 Air quality sensor line fault" are -
1. Heater core selector valve clogged with debris/ stuck open.
2. Leaking condenser/ resultant lost gas in the system (if there is a lack of gas the clutch won't engage the compressor).
** Note, the LR garage serviced the Air Con and did a re-gas just 6 months ago.
3. Faulty clutch/compressor.
The LR warranty on our car says the Air Conditioning is covered for "failure of... Compressor, condenser, receiver dryer and evaporator...".
Just trying to work my way through any faults shown by the IID tool and clear or otherwise rectify them.
Does all of this mean anything to anyone who has experience of this diagnostic fault please?
Thanks in advance. Thumbs Up
Post #287820 21st Oct 2014 6:33am
You have probably worked this out for your self but that sensor will be for the automatic setting on the recirculation function , so its not the biggest of deals . Do you have it on the auto setting ? 2008 MY Supercharged
Post #287825 21st Oct 2014 6:53am
pld118
Axle, agree it's not a big deal. Just trying to know what bit is faulting. Will check the auto setting, thanks.
Post #287831 21st Oct 2014 7:19am
pld118
Well, since Axle's post I plugged the IID tool in using all different permutations of the Air Con, heaters, demisters and the seat warming/ cooling switched on. The fault remained and would not clear.
I then switched all of the heaters, Air Con etc off completely and the fault did clear.
But, after turning the vehicle ignition off and on again, the fault code returned.
A little confused but accept it's no big deal Neutral
Post #287851 21st Oct 2014 9:15am
CG-SC
2006 Range Rover Autobiography Supercharged Zambezi Silver
I had the same fault on mine - bought a new air quality sensor and that cured it.......literally just plugs in, easy fix Thumbs Up Stolen / Gone: 2006MY Supercharged LPG Autobiography - Zambezi Silver with Sand/Jet/Jet Oxford Leather.....
Post #287896 21st Oct 2014 11:04am
pld118
Thanks CG-SC.
Do you mean this (situated within the grille on our car)?
Sensor Ambient Air:
Post #287906 21st Oct 2014 11:48am
ebajema
Looks familiar and is mounted behind the Land Rover logo in the grille Smile MY 2010 5.0 SC Galway green and sand interior!!
Post #287922 21st Oct 2014 12:30pm
Thats the external temperature sensor as stated . 2008 MY Supercharged
Post #287938 21st Oct 2014 1:07pm
pld118
So is this the part CG SC meant?
Post #287962 21st Oct 2014 3:01pm
i think its this bit Ryan, [19E702]
Post #287964 21st Oct 2014 3:08pm
pld118
Post #287982 21st Oct 2014 5:11pm
pld118
Thanks Stan, I actually found that bit you refer to (I think!) this afternoon and wondered if that was 'it'. Will keep you posted.
Post #287984 21st Oct 2014 5:11pm
CG-SC
It's the part that Stan correctly identified..... Stolen / Gone: 2006MY Supercharged LPG Autobiography - Zambezi Silver with Sand/Jet/Jet Oxford Leather.....
Post #287989 21st Oct 2014 5:41pm
pld118
Thanks for confirming that CG Thumbs Up
Post #288007 21st Oct 2014 7:02pm
pld118
Just worked out how you got that info Stan and can now - kind of - work Microcat. Very clever system.
For the part you and CG are leaning towards as the culprit with ours, namely:
Sensor Air Inlet (Re circulation) LR Part Number JTF100130 - it's only approx £20 GBP for the part.
Is it just a straightforward unplug old and plug in the new, does anyone please know?
Thanks
Post #288078 22nd Oct 2014 8:50am
Page 1 of 3 123>
