Home > Technical (L322) > Door Lights
zoso
Scotland 2013 Range Rover Autobiography SDV8 Santorini Black
Door Lights
Does anyone know what activates the interior lights when a door is opened ?
When I open any of the doors the interior lights come on except when I open the drivers door - nothing. I noticed that the switch panel on the drivers door is not illuminated either when the headlights are on so I'm thinking there is some issue with the drivers door electrics....but what ???
cheers 2017 4.4 TDV8 Autobiography
2016 4.4 TDV8 Autobiography - GONE
2013 4.4 TDV8 Autobiography - GONE
2010 3.6 TDV8 - GONE
2008 3.6 TDV8 - GONE
2002 3.0 TD6 - GONE
2006 Discovery 3 TDV6 S - GONE
2006 Discovery 3 TDV6 - GONE
2003 Discovery 2 TD5 - GONE
1999 Discovery 300 TDI - GONE
1998 Range Rover DSE - GONE
1997 Discovery 300 TDI - GONE
Post #287770 20th Oct 2014 8:54pm
Its all in the latch sir Thumbs Up
Post #287774 20th Oct 2014 9:11pm
zoso
Thanks Craig - do you know the part number of the latch so I have an idea what I'm looking for ? The remote operates all the doors except the drivers so am I correct in thinking that's all to do with the same thing ?
2002 3.0 TD6 - GONE
Post #287777 20th Oct 2014 9:21pm
Has it worked since you've had it, if not it could have had the plug pulled out by someone in the door...
Worth checking before forking out on new bits..... Pete
Post #287779 20th Oct 2014 9:29pm
SMUTT
United Kingdom 2002 Range Rover Vogue 4.4 V8 Oslo Blue
I had a similar problem.
Remote did all doors but drivers.
Acf50 and Wd40 down the lock button on drivers door and operating it with the key several times eventually made it work by remote
It also then made my one touch window opening button work on drivers door and a few other things as well ... which was nice Howard
____________________________________________________
2002 4.4 V8 LPG Tartarini
Have RSW AllComms in Cheshire J17 M6 - happy to help.
*Gone: Classic Vogue SE Auto V8 3.9 Sad
Post #287781 20th Oct 2014 9:29pm
zoso
I've had the door card off and the plugs are all okay. I also sprayed the whole lot with WD40 while I was at it but it made no difference. The one touch window works okay for the drivers side but will not operate any other windows !! The switchpack also operates the drives mirror but not the passenger side - confusing Confused 2017 4.4 TDV8 Autobiography
2002 3.0 TD6 - GONE
Post #287785 20th Oct 2014 9:34pm
cheers
Send Dan a PM with your VIN sir Thumbs Up
Post #287807 21st Oct 2014 12:09am
Look behind the bonnet pull panel, maybe a loose connection block there, with the windows not working properly as well you would think it was more than the latch??? Mind you its an FF so anything is possible...!! Pete
Post #287842 21st Oct 2014 9:51am
there's six'ish plugs you need to make sure that are properly inserted in their relevant sockets...sounds like one might be loose. ... - .- -.
Post #287848 21st Oct 2014 10:11am
zoso
Thanks - I'll take the bonnet pull panel off at the weekend and make sure all six connectors are connected securely. 2017 4.4 TDV8 Autobiography
2002 3.0 TD6 - GONE
Post #287900 21st Oct 2014 12:32pm
sorry , i meant behind the door card.. ... - .- -.
Post #287905 21st Oct 2014 12:48pm
gregdav
England 2005 Range Rover Vogue Td6 Bonatti Grey
+1 stan I had the same a few weeks back when my door cable snapped. Make sure all connectors are fully inserted even if they look like they are already, disconnect and reconnect took me a couple of off on goes before the electrics worked ok again.
Post #288059 22nd Oct 2014 6:28am
ebajema
Had the same issue with the 2006, door card had been off for new door handles and the driver one the connector wasn't on properly although it looked like it was. Installed it properly and everything started working again Smile MY 2010 5.0 SC Galway green and sand interior!!
Post #288060 22nd Oct 2014 6:54am
espaceboy
don't know if this will help
the white connector on the driver switch pack I think has the p-bus signal which covers most of the items you mention
if the drivers door card is removed and dropped to the ground then It can stress the loom at the white connector on the door switch panel cause strange issues with windows/doors.locks
I found if I held firm thumb pressure on the top of the white connector, all was good. I think the stress is in the internal crimps of the white connector, nothing visible on the loom itself. Fixed it by using a bodge - big tie wrap round the switch pack and over the top of the white connector to hold pressure
Ricky
Post #288176 22nd Oct 2014 9:04pm
zoso
That sounds feasable Ricky. I'll take the door card off on the next dry day.......next spring probably !!! 2017 4.4 TDV8 Autobiography
2002 3.0 TD6 - GONE
Post #288282 23rd Oct 2014 12:18pm
