![]() | Home > Technical (L322) > Heater-trouble-Warm on idle, cold driving. 140 cap to blame? |
Have you downloaded the workshop manual of your model yet ?? Have a look at the cooling system.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8722 ![]() ![]() ![]() |
There is an auxillary electric heater pump in the highline system (independent temp for driver and passenger)
MariusRR Member Since: 19 Mar 2013 Location: Oslo Posts: 105 ![]() ![]() ![]() |
Thank you!
Might be blocked heater pipe to/from the pump, or as it gets hot it collapses, worth having a good rummage around all the pipes to see what you can see, take them off if you can and stick a hosepipe through it... Or
THis is starting to drive me quite insane.
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2947 ![]() ![]() ![]() |
Blimey. I've had the FFRR 5 years and I didn't know about the rest heating function! |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7965 ![]() ![]() ![]() |
I won't point out its in the manual.....
so, I have to things i can try. Flushing the heater matrix. Anyone have a good tip how to?
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8760 ![]() ![]() ![]() |
Haven't read the whole post.... So my bad if it's already been mentioned.
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1511 ![]() ![]() |
I agree with the monkey above |
I took the valve out earlier this year. but the torx were corroded. So i sort of gave up. Now I am freezing to death so I will give it another try. Must just find out how to get the broken torx of and where I can get new ones if i succed getting them of.
