![]() | Home > Maintenance & Mods (L322) > Size of the hub nut? |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1862 ![]() ![]() |
36mm bi-hex |
birchyman71 Member Since: 19 Feb 2013 Location: stockton on tees Posts: 147 ![]() ![]() ![]() |
Cheers will get one before I start |
J evro Member Since: 31 Aug 2014 Location: Kent Posts: 541 ![]() ![]() ![]() |
I'm sure I had that as a question on a recent sexual orientation form ![]() |
Just changed passenger side wheel bearing today, to say it went well would be pushing it, was going to do drivers side aswell but the track rod end was so stuck it broke my ball joint separator, so sacked the drivers side.put it all back together. Passenger side ended up with the lower control arm still attached due to another uncooperative ball joint. Separated the hub and removed the race with grinder and chisel, but then none of my kit was big enough to fit the bearing so took it to a local garage who pressed it out and reassembled it all with his 10 ton press, back home and all back together total time 8 hours. On the plus side its alot quieter now. |
