Home > Technical (L322) > Heated seat not working
Andy
These things always happen when the weather changes!
Pressed the heated seat switch this morning and the two lights came on for about 5 seconds then went out. Tried several times and does it over and over.
Is it the switch or the seat that's at fault?
TIA
Post #287969 21st Oct 2014 4:18pm
PaulTyrer
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Cairns Blue
It may not be related, but earlier this year the drivers seat on ours stopped working completely, the fuse had blown but replacing the fuse caused that to blow as well. Turned out to be a break in the wiring loom under the seat which was caused by the forward/ backward adjustment on the seat.
Could be a break in the wiring.
Post #287970 21st Oct 2014 4:22pm
appj62
England 2006 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
Was the break easily identified? I have the same symptoms! Previous cars:
S-Max 2007-2013 (only diesel I've had, good car but expensive when diesely bits go wrong, so what's the point?)
Galaxy 2001-2007
Mondeo Estate 1997-2001
Sierra Estate 1993-1997
Uno Turbo 1987 -1993
Fiesta 1984 - 1987
Fiat 127 1982 - 1984
Post #288072 22nd Oct 2014 9:30am
johnboyairey
same here too. comes on for a few seconds etc. looking forward to a solution.
Post #288075 22nd Oct 2014 9:43am
PaulTyrer
Ours went in to the dealers to be fixed, took them a day to find where the break was. I had a feeling that it would be where the loom is sort of looped under the seat, and it was!
Post #288081 22nd Oct 2014 10:01am
ebajema
Have you checked for wiring and connector as sometimes connectors come loose underneath the seat.
Otherwise check the wiring of the actual heating pad for continuity. MY 2010 5.0 SC Galway green and sand interior!!
Post #288083 22nd Oct 2014 10:01am
Weejock
2002 Range Rover Vogue 4.4 V8 Epsom Green
http://www.fullfatrr.com/forum/topic22581.html
Post #288126 22nd Oct 2014 5:37pm
Vorbis
United Kingdom 2007 Range Rover Vogue SE TDV8 Santorini Black
My seat had stopped heating or cooling a couple of weeks ago and I was getting ready for the inevitable expensive repair Sad read this and as I know absolutely nothing about cars or electrics stuck my hand under the seat and had a little rummage around, found what felt like a loose connector, pushed it in and now have a fully working heated and cooled seat again Thumbs Up made my weekend Laughing
Post #288870 25th Oct 2014 6:38pm
Vorbis
Now if someone can show me where to rummage to fix the tpms I'll be ecstatic Smile
Post #288871 25th Oct 2014 6:42pm
appj62
Had the same rummage but couldn't find anything amiss. Flipping thing works now Thud Previous cars:
Galaxy 2001-2007
Fiesta 1984 - 1987
Post #288880 25th Oct 2014 8:07pm
If your light comes on for around 5 secs that means the circuit is broken... i.e. something is unplugged or a broken wire Thumbs Up
Post #288924 26th Oct 2014 12:49am
