Home > Technical (L322) > 20" Wheels
Full fat not diet
England 2004 Range Rover Vogue Td6 Zermatt Silver
ken wrote:
He can you know
FFND knows a bit about wheels I know nothing about tyres Whistle
Rolling with laughter Rolling with laughter Thumbs Up
Post #2838 6th Feb 2009 12:32pm
StevieH
Thanks for the assistance guys, I went to my local dealer and they confirmed RRS wheels OK for FFRR. You cannot fir the wrong nuts as supposedly the standard nuts will not fit later wheels so no worries there. Just have to change the tyres to correct size now to sort out rolling circumference.
Post #2871 8th Feb 2009 8:43pm
ken
United Kingdom 2018 Range Rover SVAutobiography 5.0 SC V8 Santorini Black
\\\dont forget to check the load rating of the tyre Thumbs Up
Post #2872 8th Feb 2009 11:03pm
Full fat not diet
StevieH wrote:
I went to my local dealer and they confirmed RRS wheels OK for FFRR. You cannot fit the wrong nuts as supposedly the standard nuts will not fit later wheels so no worries there. Just have to change the tyres to correct size now to sort out rolling circumference.
The old Nuts do fit newer wheels but not the other way round Whistle Please make sure they are correct. Old Nuts i think are 20mm new nuts 22mm ( Cant remember the exact measurements but i work with my eye and my magic finger test!!!!). The dealer may have got it the wrong way around but the newer wheels nut holes are bigger than the old ones and i beieve i am correct and not the dealer but i will stand corrected but please please please be sure. Shocked Shocked
In addition, RRS wheels are also a wider wheel so although you may run the correct 255 50 20 profile tyres for the ffrr they will not provide adequate protection from the kerbs so beware Whistle
I do know a thing or two about the wheels and the consequences when people get it wrong Thumbs Up
Post #2874 8th Feb 2009 11:30pm
StevieH
Thanks chaps you got me so worried I bought a set of Autobiography wheels off Fleabay. Will sell the RRS wheels as soon as the other ones arrive and then I'll check my nuts...it would be rude not to Embarassed
Post #2875 9th Feb 2009 11:01am
StevieH
Ken, can you help me with load rating, was going to buy tyres from blackcircles as they have a fitter nearby but their website only has speed ratings not load ratings although their tyre descriptions do have a number in brackets after the tyre size. Saw they had a good deal on Goodyear Eagles with a 104 in brackets after the tyre size.
Post #2877 9th Feb 2009 11:03am
Full fat not diet
What size wheels did you buy? I assume 20"
Post #2880 9th Feb 2009 12:05pm
speedymarktd6
United Kingdom 2010 Range Rover Vogue SE TDV8 Santorini Black
try this for all you need to know some is usefull some not but especially about the nuts
http://www.rangerovers.net/outfitting/tires/mkiiitires.html onto no6 Range Rover
Everyone needs a hobby
Post #2882 9th Feb 2009 3:02pm
StevieH
yes 20" 7 spoke fitted with 255/50/20.
Post #2883 9th Feb 2009 3:16pm
StevieH
Guys just shows you what the LR dealers know. Got my new wheels which are the 7 spoke Autobiographies and measured the diameter of the bolt holes and they are 23 mm. Took the nuts off my SC wheels thinking they would be a straight swap and realised some cheeky Censored had painted the OEM black ones silver. The problem with this is they only have a 20mm shank and therefore should never have been on with those wheels. Lesson learned ...if you want something done right do it yourself and dont ask a dealer for free advice hey are not interested unless you are crossing their palms. Censored
Post #2997 16th Feb 2009 11:01pm
Full fat not diet
Just as i suspected Whistle
I come across this alot and many people dont realise that their "nuts" are incorrect and how dangerous it is. This also includes many dealers that do wheel upgrades etc - spread the word
Post #2999 17th Feb 2009 12:04am
Andy
RRUK wrote:
I also believe the rolling circumference of the 19" tyres/wheels are the same as the 18" versions but not sure of the difference with the 20" ones.
The outer diameter of the wheels will always be the same. Thats why the profile gets smaller the larger you go. Otherwise, the speedo will be out.
But you knew that already!
Post #3073 24th Feb 2009 8:20pm
ken
Being playing with Powdercoat again Whistle
Post #3084 25th Feb 2009 9:02am
Full fat not diet
I recognise those bad boys Rolling with laughter
Very Very nice Ken Thumbs Up
When are we going to see pics with them on the car Whistle
Post #3087 25th Feb 2009 10:47am
ken
Week end we are fitting extra thick glass to the Rear 1/4's at the mo
Post #3088 25th Feb 2009 10:54am
