Home > Maintenance & Mods (L322) > If I drop 20mm with IID Tool do I need to do tracking
sorry , i disagree..... ... - .- -.
Post #288878 25th Oct 2014 7:47pm
Robgosty
Found a solution Thumbs Up
http://tinyurl.com/lpkpk83
Post #288886 25th Oct 2014 8:46pm
stcstc31
Ireland 2005 Range Rover SE Td6 Atacama Sand
another option
http://www.ebay.co.uk/itm/Platform-Boots-D...2a3ffadc7e
Post #288891 25th Oct 2014 9:06pm
RR2008HSE
Bellini wrote:
I believe, from reading a subject a few weeks ago, that 2007-onwards models don't have a 'motorway mode'.
Will stand corrected if wrong.
It's not as obvious. It will hunker down over 100 mph. (According to manual, NOT personal experience!!
Post #288893 25th Oct 2014 9:12pm
Mine is lowered (as i run 22" wheels & it looks like its on stilts at standard ride hight)... Lowered using the IID tool... On my last three FF's i have lowered them without adverse tyre wear! I get the geometry checked when i fit new tyres anyhow Thumbs Up
Next time you have a FF on a geometry machine, ask the operator to drop the car to access height and see how little the geometry changes!
Post #288923 26th Oct 2014 12:43am
Sandyt
I have noticed on mine that the front lowers or appears to with continued over 100 mph driving I noticed the bonnet reference points had lowered - no faults showing
Post #288948 26th Oct 2014 9:16am
steptoe
I dropped my 2002 model by 20mm using the IID tool over a year ago and can report no problems whatsoever, all tyres wearing evenly and very happy.
I do lock the height if venturing onto fast roads as mine is a 2002 model it drops to motorway height once driven above 60mph for a mile or so, and think that added to the 20mm already lowered that maybe too low for comfort.
Post #288968 26th Oct 2014 12:29pm
I lowered my 2008 car by 20mm the day I got it, 2 1/2 years later, there's no sign of adverse tyre wear.
And on that topic, I'm still amazed that there seems to be very little tyre wear at all Shocked Thumbs Up Got - 2017 SDV8 Autobiography in Loire Blue
Post #288969 26th Oct 2014 12:41pm
ebajema
If you don't have enough tyre wear you obviously don't drive it hard enough guys Twisted Evil Twisted Evil Twisted Evil
Looks like you have your answer, the 20 mm doesn't seem to make a lot of difference according to the gentlemen that have tried and tested it.
As for the highway lowering mode, I also remember it was removed around 2005/2006. The MY 2006 SC has a different suspension set up anyway if I remember correctly. Not sure about the TDV8s though. MY 2010 5.0 SC Galway green and sand interior!!
Post #288980 26th Oct 2014 2:35pm
Philip
2019 Range Rover Autobiography SDV8 Aintree Green
Does changing ride height using IID also alter the height when in Tight Tolerance Mode (as it has to be to set alignment, post-06MY)?
Post #288983 26th Oct 2014 3:13pm
Robgosty
Thanks to all for replies Thumbs Up 20mm drop it is then, anyone want to buy some bricks Whistle
Post #288984 26th Oct 2014 3:49pm
As far as I'm aware (and Patrick from GAP would be a better person to answer this) tight tolerance is set where the vehicle suspensions height is at time of setting... Thumbs Up
Post #289074 27th Oct 2014 12:10am
