![]() | Home > Maintenance & Mods (L322) > Do my headlights come to bits? |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3949 ![]() ![]() ![]() |
The situation I have is just a slight deposit, discolouration, fogging, misting - whatever, on the inside of the lenses. I'm pretty sure that a rinse out would clean and therefore fix it, question is - is it practical? and if so how? Geoff |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35832 ![]() ![]() |
they are bonded so you need to heat the edges and prise open...pretty difficult.. ... - .- -.
Well I won't be doing that then, what about taking out all the bulbs and giving the insides a quick rinse? Geoff |
problem with that would be any moisture left in the unit and although you can take the bulbs out the bulb holders will still be in there..
There may (or may not) be something in these threads that is of interest.
thanks for that VD... |
n1cktdv8 Member Since: 19 Aug 2013 Location: Cheshire Posts: 1754 ![]() ![]() |
Some years ago I gave my TD5 headlamps an overhaul and cleaned them. 3 days in a warm airing cupboard worked a treat to rid the moisture |
As VD said above, do NOT attempt to open them as they are not sealed in the traditional way & needs to be done by a BRAVE professional |
My track record would indicate that I am not a skilled professional but an enthusiastic amateur |
not very gifted with IT either, duplicate deleted |
