![]() | Home > Maintenance & Mods (L322) > Air Compressor Silica Beads replace or clean and oven bake |
| SMUTT Member Since: 30 Jun 2014 Location: Cheshire Posts: 459
2002 air compressor - was going to strip down to service or replace drier beads
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35878
anything in the wiki? ... - .- -.
| Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8825
Mine got soaked when swimming in Wales.... put them in a baking tin and gave them 30mins at 120degC lovely and dry... be careful when you take them out they tend to fly about a lot... there is a bit of fabric top and bottom to hold them in, it's against a perforated disc, mine had dirty marks where the holes were, just turned the fabric till a clean bit was in sight... Pete
| salb Member Since: 25 Feb 2012 Location: blackburn Posts: 332
you can buy a kit from fleabay........
Thanks @stan - I did check the wiki but it did not seem to give much info on buying replacements
PMSL.......
Yes I'm amased the pump worked again, it was totally under water and kicked in when I restarted the car so pumped water for a bit... was rather wet inside... sticking them in the oven certainly worked, I stripped it again 2 weeks later to check and it was all nice and bone dry... The pump dries the silica itself, in case you didn't know, the filtered dry air that it fills the system with gets sent back through the silica as it exhausts to dry it out so unless you know it has got water from somewhere there should be no reason to change it.... Pete
Thanks to both of you ... that has cleared up all my questions |
| All times are GMT |
