Home > Maintenance & Mods (L322) > Coolant type and quantity confo needed?
Zain
Ive decided to overhaul the entire cooling system (hoses/water pump/stat) rather than just replace the leaking rad. Im going to flush out the entire cooling system (incl block) as thoroughly as possible with water and replace with fresh antifreeze coolant. Is Comma G48 the correct AFC to use for a 2002 L322 4.4 Petrol? How many litres of concentrate would i need in total?
Thanks
Post #289296 27th Oct 2014 10:42pm
Check out the wiki... 17.3 litres from dry..
http://www.fullfatrr.com/wiki/Recommended_Lubricants Previously..
Post #289297 27th Oct 2014 10:50pm
50/50 mix Thumbs Up
Post #289300 28th Oct 2014 12:04am
