Home > Maintenance & Mods (L322) > whining noise - well more like.......
jakebullet64
United Kingdom 2003 Range Rover Vogue 4.4 V8 Santorini Black
Evening chaps,
it sounds a bit like a borrower playing a single note on a harmonica from in the dash.
It only occurs on acceleration and only recently started doing it.
any pointers on where to start looking will be great.
cheers
Jake. 2003 Range Rover Vogue 4.4 on Gas
1961 88" 2.25 diesel - George
Gone - 1997 3.9 V8i Discovery - Burt
Post #289456 28th Oct 2014 9:51pm
Googsy
Alertnator? Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #289458 28th Oct 2014 9:54pm
Something stuck in the blower motor? Got - 2017 SDV8 Autobiography in Loire Blue
Post #289459 28th Oct 2014 9:55pm
jakebullet64
hi mate, just read your other reply,
it doesn't do it when stationary. can this still be the alternator?
are there any ways to diagnose this?
cheers
Jake 2003 Range Rover Vogue 4.4 on Gas
Post #289461 28th Oct 2014 9:56pm
Googsy
Mm possibly not then as should be present in stationary. As Alan says might be blower. If you turn off blower does it still happen? Just wondering also might be some dry leaves stuck in vent or something due to time of year? Also is windscreen rubbers etc all okay as sometimes this becomes loose and makes the noise you describe. Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Mercedes CLK
Post #289463 28th Oct 2014 9:59pm
mjdronfield
I too wondered about leaves, but why only when accelerating? Same with windscreen rubbers.
Could be really simple or a pain in the bum to locate.
I had an issue with the plastic cover on the pollen filter vibrating at motorway speeds which sounded like a bee in the vent, but that did it above a certain speed. No acceleration needed.... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #289498 29th Oct 2014 8:09am
