![]() | Home > Maintenance & Mods (L322) > Coolant Use - What's an acceptable amount of ' loss ' ? |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3241 ![]() ![]() ![]() |
Probably not. you could have a small hole in your rad which evaporates so not leaving a trace. It will only get worse. Mine had a small loss at first, then got more and more until I replaced the rad. all good now! |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7965 ![]() ![]() ![]() |
I've probably put less than a mug full in mine over 3 years. If that. Only 15k miles though......
Thanks for the replies. They are all new radiators. I've had foibles with the bleed screw seal (o rings do little and so I use PTFE Teflon tape to seal it). The screw tends to work it's way less than air tight at times. I'm keeping an eye on it but just needed to know if small losses were within acceptable limits.
RiccartonRR Member Since: 12 Jul 2014 Location: Scottish Borders Posts: 724 ![]() ![]() |
A coolant system is a sealed system therefore any noticeable coolant loss is unacceptable in the timescales you describe IMHO.
CG-SC Member Since: 06 May 2011 Location: Falkirk Posts: 528 ![]() ![]() |
Temperature makes a big difference to the level in the expansion tank on the SC.
TugRR Member Since: 11 Jan 2011 Location: Bakewell Posts: 1200 ![]() ![]() |
I had exactly the same symptoms on my 4.4 AJV8 up until this summer - cured with a new radiator.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8760 ![]() ![]() ![]() |
Ryan, I agree with Colin, the level in the header tank is very sensitive to temperature, if the engine is slightly warm it will read high, then the next time you check it it may be stone cold, so will appear low. The level in mine fluctuates with temp, both engine and air temp.
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6819 ![]() ![]() ![]() |
I didn't know my car needed coolant |
Never topped mine up in 4 years of ownership
Thanks all. I just wondered if they lose a little over time and use.
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6424 ![]() ![]() |
I'm using about 1/2 litre every 1500 miles or so, no sign of a leak anywhere and this with a new radiator. Obviously coming out somewhere but yet to find it. Just to give some balance to the lucky ones who have a sealed system.
