![]() | Home > Maintenance & Mods (L322) > How much crud can you get in a radiator??? |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8765 ![]() ![]() ![]() |
Mine was running a bit hot... on checking with the IID tool, the temp gauge gets to "normal" ie straight up at about 75 deg, then doesn't move off normal until the temp gets over 115 deg.... so not very helpful really...
Jeez, that's a lot of crud.
SMUTT Member Since: 30 Jun 2014 Location: Cheshire Posts: 459 ![]() ![]() ![]() |
I really like the detail in your posts ... always adds to my list of jobs |
Yes Kurt, or is it Craig...!??!?!??.... I've doubled our water bill this quarter and I did stick a flushing agent through it...
Craig and I are like Clark Kent and Superman - although I'm not sure which of us is Superman.
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
A good pal of mine had to change the rad on his 4.6 P38, took a lot of effort to remove the old one, he reckoned it weighed 10 kg more than the new one.
miggit - that's what Pete wrote in his post. |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7988 ![]() ![]() ![]() |
Wow. Really illustrates the issues that a bit of crud can cause, especially if it goes unnoticed over an extended period of time, not that yours has....
This really high-lights the importance of using the correct water and anti freeze mix. If you use methanol based anti freeze it will react with the aluminium in the engine causing all sorts of corrosion issues.
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16400 ![]() ![]() ![]() |
And TD5/TD6 engines... Put the wrong antifreeze in and it will eat your head gasket |
Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1528 ![]() ![]() |
Excellent post!
