![]() | Home > Maintenance & Mods (L322) > Before you get under a car supported by a hydraulic jack... |
This is the nose of my trailer supported by a 3500kg hydraulic trolley jack. There's less than 100kg on it.
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2286 ![]() ![]() ![]() |
Wise words indeed |
Mark L Member Since: 29 Oct 2014 Location: Tamworth Posts: 121 ![]() ![]() ![]() |
I had an idea the other day...
SMUTT Member Since: 30 Jun 2014 Location: Cheshire Posts: 459 ![]() ![]() ![]() |
@MarkL - Check out @Joe90 gallery - I think he beat you to it. Howard
Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1902 ![]() ![]() ![]() |
Im using my old pitch pine beams from the house decorating (renovation really |
Struggling to find that one. Sounds interesting. Have you a link to it at all, please? |
Here's Joe's thread.
Top man - thank you.
That jack probably only needs bleeding. Open the lowering valve fully, pump the handle up and down 5 times then re-test. The cheaper jacks don't have the auto-bleed thingy as I found out a while back. |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8798 ![]() ![]() ![]() |
I just use a piece of 2x4.... works fine for me....
"I just use a piece of 2x4.... works fine for me.... "
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3666 ![]() ![]() |
Going under a car thats on axel stands is safe as houses, but like houses they need a good foundation, so make sure you are on concrete and that the car is sitting safely on the stands. When I lower the car on to stands, I leave the jack 1/2"" below the car and give it a dam good shake. That way if something has gone Pete Tong the car will jump back on to the jack and not hit the floor! Once I've given the car a good shaking and it hasn't moved, it is safe to approach!
Caught my neighbour throwing a cigarette butt onto my garden, so I lent him my jack.
