![]() | Home > Maintenance & Mods (L322) > L322 Heated windscreen - diagnosing fault |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8795 ![]() ![]() ![]() |
They do tend to die after a while, as the windscreens get older, they start to delaminate around the edges, this breaks the small wires running through the screen and stops it working... fix is a new screen...
birchyman71 Member Since: 19 Feb 2013 Location: stockton on tees Posts: 147 ![]() ![]() ![]() |
Think the circuit may be split into two with a relay for each half so could be the relay, before I got a new screen mine used to be stripey when defrosting which was related to the elements breaking down |
Cryptic Member Since: 01 Apr 2014 Location: Manchester Posts: 63 ![]() ![]() |
Okay, thanks both - I'll have a hunt for the relays first off - any clues as to where they are? |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8774 ![]() ![]() ![]() |
Mine was stripey, I just happened to get a crack up the screen and get it swapped by autoglass, now works fine.......
