Home > Maintenance & Mods (L322) > C TEK
J evro
England 2008 Range Rover Vogue SE TDV8 Stornoway Grey
C TEK
Anyone use there ctek charger using the 12v acc/ cigarette lighter socket ....and does it work ok, rather than the croc clips onto battery?
Post #289684 30th Oct 2014 3:45am
You will need to make sure yours stay live after complete shut down about 20 minutes, depending on model some or all the power sockets go off line when the car is full asleep . 2008 MY Supercharged
Post #289688 30th Oct 2014 4:46am
ken
United Kingdom 2018 Range Rover SVAutobiography 5.0 SC V8 Santorini Black
I use a Martin CTek plug in the tow socket Thumbs Up
Post #289696 30th Oct 2014 8:19am
appj62
England 2006 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
The one in the boot area is also supposed to stay live if you haven't got a tow socket. Previous cars:
S-Max 2007-2013 (only diesel I've had, good car but expensive when diesely bits go wrong, so what's the point?)
Galaxy 2001-2007
Mondeo Estate 1997-2001
Sierra Estate 1993-1997
Uno Turbo 1987 -1993
Fiesta 1984 - 1987
Fiat 127 1982 - 1984
Post #289697 30th Oct 2014 8:25am
Joncey
Jersey 2010 Range Rover Autobiography 5.0 SC V8 Santorini Black
Get your self one of these it will save you loads of messing around
http://www.disco3.co.uk/shop/towing-socket...c-p45.html
Post #289702 30th Oct 2014 9:07am
Martin
Site Admin
Thanks for the recommendations guys Very Happy
Post #289703 30th Oct 2014 9:08am
J evro
Thanks guys
The 'Martin route' would have been my first choice alas I have no towbar/socket fitted as yet, I will see if the boot socket is live permanently when I get the RR back as it's in having the FBH checked out today,
Would it actualy need to be permanently live even though it's being fed power ( from the 240v Ctek ) rather than providing power for charging ?
Post #289762 30th Oct 2014 2:09pm
ken
Re: C TEK
Connect direct to the battery using the comfort charge method if no tow option
Post #289916 31st Oct 2014 8:38am
Nomad
United Kingdom 2012 Range Rover Autobiography 5.0 SC V8 Zermatt Silver
I've used both the front cig lighter socket (mine was made live by the dealer when i bought the car) with cable out under door and also the rear accessory socket with cable out between upper and lower tailgate. Being doing so for years. Works really well. Often left charging for months at a time. Ctek are highly recommended. Thumbs Up 2012 5.0L S/C
Previous:
3.6 TDV8
4.4 HSE
P38 4.6 HSE
Classic 3.9
90 County
Series3 Lightweight
Post #289918 31st Oct 2014 9:02am
I use a Ctek connected to a socket in the car without any problem at all.
It must however be a socket that is permanently live to work.
Permanently live means it is directly connected to the battery at all times, conversely a non-permanent socket is fed thro the ignition switch and as such is only connected to the battery when the ignition is on.
Post #289919 31st Oct 2014 9:04am
I just connect my CTEK to the battery via the connector lead supplied with the CTEK
Post #289936 31st Oct 2014 11:15am
J evro
Re: C TEK
A what ?
Post #289963 31st Oct 2014 3:10pm
J evro
Thanks, looking for an option where I do not have to lift the bonnet each time I want to go out in it Thumbs Up
Post #289964 31st Oct 2014 3:12pm
J evro
Will check this when I get it back Thumbs Up
Post #289965 31st Oct 2014 3:13pm
J evro
Post #289966 31st Oct 2014 3:14pm
