![]() | Home > Technical (L322) > MY 2010 wil not start |
Renegade2 Member Since: 03 Dec 2011 Location: Cardiff Posts: 134 ![]() ![]() ![]() |
Hi guys not sure if anyone can help or have an idea.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35861 ![]() ![]() |
i'd check the battery first.....there might be enough power to operate a few items but not enough to start it.. ... - .- -.
Have today charged battery but made no diffrence.
Hi thanks for reply. Battery was changed under warranty a while ago as there was a recall but that was several years ago.
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3986 ![]() ![]() ![]() |
Could you take the battery off the car and transport it to somewhere that can test it for you?
CSK Member Since: 15 Oct 2010 Location: St Tropez Posts: 750 ![]() ![]() ![]() |
I had no warning telling me the battery was weakening. Just one day jumped in the car, pushed the button and nothing so it might be the same problem.
you might be charging the battery but it might not be holding the charge..get a drop test done to see if its ok.. ... - .- -.
From what height should it be dropped from? ![]() ![]() |
Happy to get a battery but how on earth do you get the thing out on a 2010, hardly had room to get the battery leads in lol, tighter than a |
You can but it's a real squeeze. To be honest I had my local Renault garage fit it for me but he had a hard time! |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8822 ![]() ![]() ![]() |
Put the bonnet in access mode, then it's much easier... Pete
Have a look at RRUKs (Adam) post on the battery saga with his 2010 SC |
Have you been able to start the car yet? |
lucky Member Since: 18 Apr 2014 Location: colchester Posts: 87 ![]() ![]() ![]() |
had a similar problem with my10 vogue, tft went blank, lcd screen went blank whilst I was driving, lights still worked and indicators ok, got home turned off ignition tried to restart but car did not turn over. had to get it recovered to local dealer, fault was a wire had frayed on subframe and shorted to earth behind left hand cover in boot. problem sorted with sticky tape ! |
