Home > General > Amp or Speaker fault - 2002 TD6
liverpoolphil
United Kingdom 2003 Range Rover HSE Td6 Tonga Green
I know the passenger side rear speaker is faulty and I need to replace....
by the way, there are 2, I assume one is low range and one mid? Can anyone get me the part numbers?
But....the other day I got so pi**ed of with the crackling speaker that I faded the speakers to the front only, it turns out the front passenger side is also faulty (kept going on and off - almost like a loose wire)
will this be a couple of faulty speakers or could something else be the issue?
Anyone got any suggestions?
Post #29008 23rd Sep 2010 3:08pm
Macdaddy
2003 Range Rover Autobiography 4.4 V8 Java Black
A common fault is the amp gets water inside it either from a leak or condensation.
Mines suffered this and currently I've only from speakers working.
The amps been removed and looked at and isn't fixable Sad
It's more likely to be the amp than both speakers. TDV8 HST Sport **Current**
4.4 V8 Autobiography and 22" wheels **Gone**
Post #29015 23rd Sep 2010 4:47pm
iT LAD
Shocked It's a bit disturbing that water leaks into that area so often... I keep reading about it lately. Is it a design fault...
Post #29017 23rd Sep 2010 4:52pm
SteveMFr
Site Sponsor
Not really a design fault if my previous cars are anything to go by. I'm surprised they keep dry so long, actually. The oldest LM's are going towards 9 yrs. now - and if seals/sunroof drains/etc. were not serviced properly (who's are?) then at some point, you have water ingress. But I digress... Rolling Eyes
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #29019 23rd Sep 2010 5:21pm
Dolphinboy
Phil, i had exactly the same problem. Look in the rear left side panel in the boot - there is a socket on the top of the amp with a junction box of numerous wires going in. Take this out and you will see that probably some of the little "spikes" in the cluster (around 12-16 in total I think) are bent and not making a contact with the inserted junction box. That was what was wrong with mine anyway. It's all good now as I used tweezers to straighten out the spikes so the plastic contact box slid on properly and made contact on all the spikes. (I only have one box in the rear as I am poor and only have an HSE!)
Post #29040 23rd Sep 2010 7:53pm
Macdaddy
It's also caused by the amp getting hot and as it's in a void condensation building when it's colder outside at night. TDV8 HST Sport **Current**
Post #29075 23rd Sep 2010 9:57pm
liverpoolphil
had a quick look at the plug, couldnt see any obvious bent spikes but upon refit the whole system sounded much better. May well have been some water ingress as I did use that particular area for storing my fishing waders (always wet Big Cry ) so much so for trying to use all the of storage space 'smartly'
cheers for your help Bow down Bow down
Post #29103 24th Sep 2010 9:51am
SteveMFr
Site Sponsor
Shocked Shocked Shocked
You're kidding, right?
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #29152 24th Sep 2010 11:05am
liverpoolphil
Embarassed Embarassed Embarassed
Post #29171 24th Sep 2010 12:12pm
skippy
United Kingdom 2007 Range Rover Vogue SE TDV8 Rimini Red
just like to say i had water coming in to the boot/entertainment area and after taking the whole back end to bits finally found that under the outside e pillar covers the trim clips have a foam water stopper on and over time these wear down and let water passed what i did was took the e pillars off and the trim clips and put some all weather sealant (not sanitary sealant as this will go mouldy after time)round the trim clip that goes onto the body and then refit this has stopped my water getting in anyway hope this helped anyone
Skippy 07my 3.6 tdv8 vogue se in red
Post #29309 24th Sep 2010 9:50pm
liverpoolphil
went back to normal on way home Sad bit more investigation in order I think
Post #29312 24th Sep 2010 10:28pm
liverpoolphil
spent some time on this this morning.....noticed a clear difference in sound quality between the left rear and the right rear.
I removed both door cards and swapped the speakers, it was then obvious there was nothing wrong with the speakers (as the ones I thought were dud worked perfectly on the other side)
So I guess its something to do with the amp / wiring. Big Cry
The right (faulty) side seems very intermittent, it you go over a bump or close the door heavily, it goes really crackly and shi**y sounding
Where do I go next? (had a quick look over the amp plug but cant identify anything wrong that end)
Post #31265 9th Oct 2010 11:54am
Macdaddy
You need the amp testing, or perhaps swap with someones who's works to check if it's your speakers. TDV8 HST Sport **Current**
Post #31290 9th Oct 2010 7:10pm
liverpoolphil
are the amps expensive? Do they have different types (for different models) may just buy one of 'the bay'
Post #31314 10th Oct 2010 11:09am
Macdaddy
Not sure on new but they are around £250-300 on fleabay. TDV8 HST Sport **Current**
Post #31326 10th Oct 2010 4:46pm
