![]() | Home > Technical (L322) > FBH again! Which Battery? |
J evro Member Since: 31 Aug 2014 Location: Kent Posts: 541 ![]() ![]() ![]() |
Hi, I initially had this with mine replaced battery and fob then flashed 8 but at a slower rate and still no FBH start up , have you set it up on the screen timer just to see if the burner fires up? At least you will then have narrowed it down somewhat ..
Lad Member Since: 12 Oct 2014 Location: Blackburn Posts: 284 ![]() ![]() ![]() |
Just set timer but it didn't fire. I'm sure it was on this morning when I came to work, when I switched off the engine and got out I could hear it running. And could smell the normal smell that they give off. I've had a D3. Just thinking I wonder if it's the fuse. Where would I find that? |
What did it actually do when you set the timer, ? |
Well before 2pm this afternoon I set it to start at 2pm. I came out about 2.15 but I couldn't hear anything. There wasn't any smell of fumes, looked on the screen inside and it showed nothing. Not that I expected anything.
Well fuse is ok. Checked other fuses whilst in there and they all ok.
I've now set timer to come on early in the morning. May not wanted to come on this afternoon as it may have been too warm. Air temp not car temp. I'll let you know if it works tomorrow |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8760 ![]() ![]() ![]() |
Will not work if 16 deg or over. There is nothing that can't be fixed with a hammer😜😜
HHHMMMM, we did have a fair bit of sun today. Not sure about temp tho. I'll see if it works in the morning. It says it is going to be cold tonight. I had Pete's FBH GSM remote on my D3. A quick text/ring and it fired up. Had a few settings that you could change. |
Discotigger Member Since: 12 Feb 2013 Location: Cumbria Posts: 804 ![]() ![]() ![]() |
EDIT> Changed the battery in the fob for the one stated in the handbook on page 103, being CR1/3N.
It was just one from maplin, thought I'd try it to see and if it worked, and if it did I'd get a duracell. The battery from maplin has a blue sleeve around it and I thought it was stopping the battery contacting the brass strip seen within the fob, I pulled the brass contact up a little and I'm sure its touching it but you can't see if it is, doesn't help the light not coming on either. |
I'd definately get a Duracell I/3N, much more reliable than Mapln batteries |
Aye! Will have a nosey on there later |
Might also be worthwhile trying the fob pairing procedure when you put the new duracell battery in, if the fob battery has died it may need repairing to the remote. |
True. Now how do you do that |
