Home > Maintenance & Mods (L322) > A-Pillar Interior Leak (not sunroof drains)
Dean
Scotland 2007 Range Rover Vogue TDV8 Java Black
Hello all,
When it rains I get a leak seeping through the drivers side A-pillar interior lining on my 07MY FFRR TDV8. It emerges about 3/4 of the way down and drips onto the top of the air vent at the end of the facia.
I had a look at the 2 drain holes for the sunroof, but when I poor water through these it freely emerges under the car and no leak appears.
Anyone got any idea what the problem could be?
Thanks for any help,
Dean 2006 FFRR TDV8 Vogue
2012 Discovery 4 SDV6 GS
Post #290824 5th Nov 2014 8:53am
windscreen or maybe the door rubbers..use tape and check with water.. ... - .- -.
Post #290836 5th Nov 2014 9:47am
TugRR
Poorly fitted replacement windscreen - that's what happened with mine
Thumbs Up Where do you go after one of these . . . ?
Post #290870 5th Nov 2014 10:53am
JPS
2005 Range Rover Autobiography Td6 Zambezi Silver
I had the same thing on mine just a couple of days ago and am drying it out as we speak, i took the A pillar trim off and poured some water down the screen and it was coming in quite fast, dryed it all off and then sealed from top to bottom of the screen, is nearly bone dry inside now and touch wood seems to have solved the problem, mine had a new screen fitted about a year ago so if yours has had the same at some point in its life then will most likely be the same problem.
Post #290904 5th Nov 2014 12:19pm
