![]() | Home > Technical (L322) > Rear passenger air con |
paulmoran2 Member Since: 27 Nov 2013 Location: Leeds Posts: 1422 ![]() ![]() ![]() |
Press the "Rear Control Isolation Switch" on. It's usually located on the front central control panel bottom left (thanks Ian) and looks like a picture of the rear half of the car with 2 wind arrows pointing towards the rear.
T24RES Member Since: 22 Nov 2010 Location: Henley-on-Thames Posts: 936 ![]() ![]() |
bottom left switch |
Lad Member Since: 12 Oct 2014 Location: Blackburn Posts: 284 ![]() ![]() ![]() |
Yes, I saw that and pressed it but still cool air came out. I don't think the fan speed increases either. I had a play this aft, and I did get warm air out but I pressed Max Air Con or something, top left button.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35770 ![]() ![]() |
not sure but the heat/cold might be in unison with the center dash air vent control, the one just above the hazard switch... ... - .- -.
Stan that temp control is on warm. I know it will give out warm air as I got it to do it, but I'll play tomoz as I'm trying something else out on it and see what settings I have changed. |
