Home > Maintenance & Mods (L322) > Crank Breather PCV hoses - which way round to connect?
SMUTT
United Kingdom 2002 Range Rover Vogue 4.4 V8 Oslo Blue
The top hose (item 3 in diag) from my Oil / Cyclone valve (item 1) is connected to crankcase
The bottom hose is connected to the PCV valve like below.....
This is contradicted in the next image below which shows top hose to PCV
But which is correct - what have you got.
I have not got round to working the flow of everything to see which would look more correct - does anyone know?
.. Howard
____________________________________________________
2002 4.4 V8 LPG Tartarini
Have RSW AllComms in Cheshire J17 M6 - happy to help.
*Gone: Classic Vogue SE Auto V8 3.9 Sad
Post #291029 5th Nov 2014 9:16pm
Pretty sure mine is as the bottom diagram, can't think it makes any difference as both pipes go to the cyclone so doesn't matter which way round they go... Pete
2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior-Click here for Thread-
Post #291052 5th Nov 2014 10:18pm
Jamiehol
United Kingdom 2007 Range Rover Vogue TDV8 Stornoway Grey
I replaced mine a coupe of weeks ago and they were connected like the first picture, this is on a car that has only done 62k so assume I replaced the factory ones.
Post #291057 5th Nov 2014 10:26pm
RRPhil
Don’t know if it helps but this photo is from the workshop manual :
and this from a BMW X5 forum :
Phil
Post #291104 6th Nov 2014 12:57am
SMUTT
Thanks all for your resposes...
@Jamiehol - I think my installation is from new (only 89000 miles) like yours.
@Haylands - Initially I thought the same - it does not matter the direction, however if you are pulling oil laden air from crankcase into the separator I think you would want it on the lower OSV pipe, so that gravity would drag the heavier oil down, thereby allowing the cleaner air to be sucked upwards and into the pcv (if indeed that is the air flow direction - still not sure if I have got my head around how it works)
@RRPhil - thanks very much for the taking the time to find these photos - very enlightening - and they kind of agree with my own thoughts on it. In fact my gut feeling when I saw the hoses on mine was that it looked wrong which is what sparked the whole investigation.
Overall I think I have 4 votes to do it as per photos and 2 to connect as per top diagram.
As I like to think I am Democratic (SWMBO would prob suggest Autocratic, maybe even Arthritic) - I shall swap mine to suit the photos.
It is for the greater good.
Thanks to all. Thumbs Up
... Howard
Post #291136 6th Nov 2014 10:15am
Jamiehol
Looks like I'll be swapping the hoses on mine when I get it back from the LPG installers.
Post #291542 8th Nov 2014 7:53am
p38arover
Australia
What is the part no. for the PCV? I can find the hoses and the cyclone in MicroCat but not the PCV. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #484350 26th Jul 2018 8:24am
nicksaab
2016 Range Rover Vogue SE SDV8 Corris Grey
Try LKR000040LR Current Fleet:-
2018 Discovery 5 3.0 HSE
2021 Ford Ranger Wildtrack
2019 Ford Mustang Bullitt 5.0 V8
1993 Defender 90 200TDI Pickup
Gone - not forgotten
2016 L405 4.4 SDV8 Vogue SE
2012 L322 4.4 Westminster
2004 L322 4.4 V8 Autobiography LE
2000 P38 RR 4.0 HSE (ex Clarkson test car)
Post #484413 26th Jul 2018 10:21pm
p38arover
Australia
Excellent. Thanks very much, I still can't find it in Microcat. It's illustrated on the page where the oil separator and hoese are shown but in grey and with no part no.
Now should I buy the high priced LR/BMW part or one off eBay? Smile Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #484424 27th Jul 2018 3:15am
