![]() | Home > My Range Rover > 2005 Facelift TD6 Vogue high miler |
I don't mind doing a few reds and blacks followed by some après ski and tour reps lol
Well even though i cant drive it i woke up to ice covered windows today so thought i'd give the park heat a try off the fob.
Latest error list from the faultmate
The glowplug relay i cant be sure about until i get the rough running sorted out but it could also be a glowplug causing the error if memory serves me right ![]() I think my stating issue is related to P1180 so need to look at why thats showing is low P0101 is likely from the air pipe being off so much P0191 is maybe related to P1180 so have to work through the list as the fuel flows into the engine. The LP pump isnt that old so the filter will be binned first of all as part of its service. and some videos for light entertainment.. FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's Mantec Sump Guard, Rigid Load liner, MY10 BT upgrade. ![]() |
FINALLY!!
Well I still haven't done the fuel rail pressure sensor but hoping to get to it this weekend!
Well time for an update!
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16394 ![]() ![]() ![]() |
Will, check how much oil is in a Mobil1 container... Lots of them are only 4ltrs pal |
Cheers fella just ran over and double checked |
Always worth making sure though fella |
Well another thing on the list has shown itself...
Still waiting for the sodding d2s bulb to arrive to fit to the FF, and also scouring for a decent priced rear wiper motor assembly |
Well time for another update!
clemenz Member Since: 13 Sep 2014 Location: Graz Posts: 183 ![]() ![]() ![]() |
what leds did you use for the sidelights? no flickering when they are checked? |
These are the ones I got Clemenz,
