![]() | Home > Off Topic > I'm getting 4 new tyres already for the Jag |
As you know by now have now an XJ . I pointed out that car could do with alignment and ride was a bit jittery to garage who are reputable and are members of various standards and bodies etc etc It's all good as it's going back in Monday anyway. Today I got a tpms warning. It seemed to sort itself. I decided to have a look a tyres all of which have great thread and like new. On checking the load index I noticed that the rear tyre stated 98 whilst the front was 93. I referred to handbook and apparently minimum on rear should be 104 and front should be 102 |
Yes going up is fine but down is a no no |
RiccartonRR Member Since: 12 Jul 2014 Location: Scottish Borders Posts: 724 ![]() ![]() |
+1 for fitting stations being held accountable |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8775 ![]() ![]() ![]() |
109 on 20" for the ffrr and 112 on 19"
Why do you need to overspec so much? thats already taken into account with the standard weight spec on most vehicles.
I guess there could be a good argument for "over-rated" tyres on a 4x4 though. Take using 109's for example. Once you go cross-axled you will be taking the majority of the vehicles weight on just two wheels with a third taking a wee bit and this will probably be on stoney ground which is already doing its best to nip the sidewalls. At that point, even if your car is at mminimum curb weight you've overloaded the tyres and again those rocks will be doing all they can to destroy your sidewalls. We then, using the same tyres, hop on the motorway with a car full and hammer along for hours on end without giving a thought to the rubber other than how much tread there is - never a worry about internal damage to the carcase. I'd rather play safe and go up one plus in my size the load index went from 106 to 114 with little choice in-between. Now for the funny / stupid bit - my car came with OF 22" rims fitted with Pirelli 106 rated tyres. Around these parts, accessing farm land or going to meet friends for rides with the horse trailer, we regularly go off-road and 285/35R22 106W tyres look like they're about to get ripped to shreds ![]() So, after following threads on here, I've ordered a set of 305/40R22 114V XL tyres and have hot air gun ready to make the necessary mods to the rear OS arch liner ![]() Once all is done I'll post a pic or two so you get the idea and have the opportunity to have a good laugh ![]() |
^thats a fair point about off road driving.
"305..... Thems some wide tyres!"
You make light of this phenomenon. Just exactly how much weight do you class as "a bit" ?? All those on here with any kind of Engineering Degree will tall you it's quite a bit more than "a bit". Towing a trailer, downhill with some ballast in the car (wife, kids luggage etc) I'll tell you that you'll be weighing a lot (LOT) more than 650KG per front corner then. Jam the brakes on and at least a couple of tonnes moves it's point of moment forwards to the front wheels. Then run over a bump in the road under those conditions. How much energy does that transfer to the tyre? Put your fingers in and find out ![]() Oh yeah, you definitely need over a tonne per tyre at that point. ![]() |
I don't understand why weight rating is so little looked at or published. I always check the weight rating on tyres before I buy, but the information for many cars is hard to find.
RR2008HSE Member Since: 06 Jan 2013 Location: British Columbia Posts: 2932 ![]() ![]() ![]() |
Personally, I think the manufacturer's standards should be fine unless the car was being used in a very nonstandard way. However, overspecing can't hurt and, if it makes you more comfortable, |
