![]() | Home > Technical (L405) > Fuel Burning Heater |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35829 ![]() ![]() |
there is FBH info in our wiki and did you have the heat turned 'on' .. ... - .- -.
5.0 Member Since: 25 Feb 2012 Location: Surrey Posts: 721 ![]() ![]() |
The wiki does not have the answer. The heating was on in the respect that it was set at 20 degrees and was on Auto. |
So it seems that the temperature has to be set at a higher level on the dash. I put it up to 24 degrees today and gave it a go. Toasty warm in no time. I am quite impressed having never had this feature before (it has never been standard fit on my previous S/Cs). However I don't understand why the temperature needs to be set higher than you would normally have it set. It's a bit of a nuisance if I have to remember to bump up the temperature dial everytime I leave the car in case the next time I use it I want the FBH on beforehand. If the actual cabin temp is below the selected temp logically it should heat to that selected temp whatever it is? Has anyone else experienced this? |
CubaLibre Member Since: 12 Jun 2014 Location: Herts Posts: 12 ![]() ![]() |
TIMED CLIMATE CONTROL OPERATION
Hobo729 Member Since: 14 Dec 2014 Location: Limassol Posts: 43 ![]() ![]() ![]() |
Wow - that is some explanation - where did you find that immense level of detail? I have to say that I now understand a great deal more than I did and several things I have noticed now make sense - shame most Land Rover Dealer technicians don't have the same level of knowledge:) |
So impressed with CubaLibre info I forgot to ask a question - I have to operate the remote transmitter almost touching the car before it will activate the remote heating. The remote has been changed and has been fitted with new batteries but with no improvement - any one else had this problem yet? |
Mark L Member Since: 29 Oct 2014 Location: Tamworth Posts: 121 ![]() ![]() ![]() |
The remote for mine works from any room in the house.
At least you hear when yours is working |
crookedm Member Since: 23 Sep 2012 Location: Heswall Posts: 698 ![]() ![]() |
Worth every penny these, good uk build quality. ![]() |
wealy Member Since: 29 Jul 2013 Location: Kings Bromley Posts: 1020 ![]() ![]() ![]() |
Anyone know what it looks like under the bonnet?
Phil. Member Since: 19 Apr 2010 Location: West Midlands Posts: 793 ![]() ![]() ![]() |
You can set the FBH timer from the main screen if you don't have a fob. If it's not on the screen then their is a fair chance it isn't fitted. MY23 D350 HSE
Where is it on the screen? |
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 845 ![]() ![]() |
Mark
Home screen - extra features - timed climate MY23 D350 HSE On my 7th RR plus various other JLR vehicles |
