Home > Maintenance & Mods (L322) > Plastic trim attachment tape
fanders
United Kingdom 2009 Range Rover Autobiography 4.2 SC V8 Buckingham Blue
I'm having some plastic trim parts colour coded at the moment (will post pictures when back on the car), and so removed the clip on Powerful mirror trim covers as part of this - easy with a bit of heat from a heat gun. They were attached with rubbery double sided adhesive tape, fairly thick - see photo. Does anyone know where I can source this stuff from, as I'll need some more when I reattach the mirror covers this coming weekend?
Cheers, fanders
Post #292072 10th Nov 2014 9:11pm
its the famous 3M tape, ebay is your best bet.. ... - .- -.
Post #292075 10th Nov 2014 9:24pm
fanders
Good idea Thumbs Up
Post #292116 10th Nov 2014 11:22pm
miggit
http://www.toolstation.com/shop/Adhesives+...ape/p63962 Yesterday I couldn't spell Engineer... Today I are one!
Post #292192 11th Nov 2014 1:56pm
i have 3M tape and that ^ one and the mammoth stuff is very good.. ... - .- -.
Post #292194 11th Nov 2014 2:03pm
miggit
You wont beat the 3M tape for strength, but it can be a pain to get hold of. That Toolstation stuff is readily available and will do the job, especially if your in a hurry! Yesterday I couldn't spell Engineer... Today I are one!
Post #292197 11th Nov 2014 2:17pm
that mammoth tape is holding on my rear AB badge so its pretty good stuff although a bit 'sticky' when cutting it. ... - .- -.
Post #292198 11th Nov 2014 2:19pm
Just be aware there is a lot of counterfeit 3M tape for sale of fleabay!!! Don't want your mirrors falling off next week Whistle Rolling Eyes
Post #292201 11th Nov 2014 2:29pm
Ianmaney
United Kingdom 2011 Range Rover Vogue SE TDV8 Mariana Black
Its called VHB tape and used by us in the sign industry, however its not cheap, best thing to do is find a sign manufacturer or sign fitter locally and see if they have a roll end they can spare, they may just give it to you, its around £60 a roll for the 25mm width.........
Post #292308 11th Nov 2014 9:42pm
stuck mine on with Soudal Fix all crystal........
pretty solid, will beat most tapes Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #292314 11th Nov 2014 9:52pm
miggit
Actually thinking about it, if you really don't want them to come off ever again, then you need some PU flex adhesive / sealer. Sometimes called sikaflex PU, but know to us in the trade as jollup! Jollup is the best thing since sliced bread, they use it to glue commercial bodies together, windscreens in place and lotus elise's body on to the chassis, all be the latter 2 are industrial strength. But you get the idea!
this is the stuff! http://www.ebay.co.uk/itm/PU18-Polyurethan...1c3f9f6ae6
You can get it from all car paint suppliers, and most motor factors. Prices should be under a tenner, and if you don't go for a brand one should be a fiver.
If you get covered in it, and trust me if there's any chance of getting it on you, you will, White Spirit is one of the best / cheapest solvents that works with this stuff, when it's wet. If it drys then dynamite wont shift it!
Very good for fixing all sorts of trim, like the covers on the bottom of the doors, bumpers that the fixing clips have been broken on, in fact just about any thing to any thing. I've even used it on soil pipes before when all else has failed, takes a couple of hours to flash off full strength is with in 24 hours, and then you'll brake it before it comes apart Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #292362 11th Nov 2014 11:43pm
agree that is super strong,
Also sikka512 is also good, use it on caravans to re seal rails and joints. There is nothing that can't be fixed with a hammer😜😜
Post #292367 11th Nov 2014 11:50pm
