![]() | Home > Maintenance & Mods (L322) > MOT tomorrow.... |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35770 ![]() ![]() |
good luck Mark...i'm sure all will be ok |
RiccartonRR Member Since: 12 Jul 2014 Location: Scottish Borders Posts: 724 ![]() ![]() |
As Stan said - Good Luck |
Good luck Mark |
Chauch Member Since: 09 Feb 2014 Location: Beds Posts: 303 ![]() ![]() ![]() |
Good luck, I really need to take mine in as well and same fears over the brake lines... 4.2 Supercharged Vogue SE |
Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1901 ![]() ![]() ![]() |
As others have said, good luck fella, sure it be fine |
Mark L Member Since: 29 Oct 2014 Location: Tamworth Posts: 121 ![]() ![]() ![]() |
Mine came back with an advisory on the lower front suspension arm bushes this afternoon.
^ At that price its not a genuine LR bit, more britpart! |
If it lasts more than 4 years it'll be doing better than the factory fitted pair that are on it now! |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8760 ![]() ![]() ![]() |
Cheers chaps |
ok until next year then.. |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8723 ![]() ![]() ![]() |
Well done on the two passes, play in the rack is more than likely a rack end, now it's started it will degrade quickly, they are pretty cheap and easy to do especially if they have it apart to do the brake pipes.... Pete
Good news, well done |
I know there are joint couplers available to do this but I've never seen a garage use them, why would you want to add another potential leaky area into a safety system. Best pay the mechanic £80 to do the work if you're not sure about doing it yourself...What price safety?!!! p.s. might be worth changing the flex pipes while you're at it ![]() |
