Home > Maintenance & Mods (L322) > SC leaking oil - Ladder Frame... Or something
Page 3 of 4 <1234>
was this gasket something the dealer had already done Ryan?.. ... - .- -.
Post #292748 13th Nov 2014 2:56pm
pld118
Stan, last time the car was in, they indicated a possible loose bolt, inferring at the time that it was leaking from one of the bolts I've previously shown on the photographs. So they said they'd tightened it and used thread lock hoping it would resolve but they did say monitor and report back any problems.
They've never replaced the seal on ours before though.
Post #292749 13th Nov 2014 2:57pm
pld118
Sump gasket seal diagnosis was reviewed.
Futher investigation concluded that the leak is in fact from the Ladder Frame seal which is estimated at 20 to 30 hours labour and an engine out job. LR warranty initially declined to cover this leak. Warranty engineer today confirmed the Master Tech diagnosis and agreed that this is a claim that will be covered by warranty.
Post #294594 21st Nov 2014 6:18pm
Well that was a result, shame you had to intervene, still, nice and cheap for you.... Pete
Post #294612 21st Nov 2014 7:49pm
pld118
Another justification - for our RR anyway - for investing in the LR extended or some other good warranty (on MD rates, the cost of this claim alone appears to exceed the annual premium).
Post #294614 21st Nov 2014 8:03pm
you have such a persuasive way with words Ryan, glad its going to be sorted.. Wink ... - .- -.
Post #294616 21st Nov 2014 8:07pm
Well that is a result, a bit of lightly applied pressure on the warranty provider can sometimes be required, however in LR defence "external oil leaks" are excluded so you did well there! And at least with the engine out they will be able to see the whole engine to assess if this is the only leak......
Anything else worth doing whilst the engine is out? There is nothing that can't be fixed with a hammer😜😜
Post #294625 21st Nov 2014 8:37pm
pld118
@nmj,
I don't actually know what the ladder frame does.
It's a good point re anything else worth doing whilst the engine is out if anyone knows.
Post #294630 21st Nov 2014 8:57pm
pld118
Just got the car back after over 5 weeks in the garage for the engine out and Ladder Frame leak to be fixed.
They have also replaced the alternator belt and the supercharger belt at the same time.
Fingers crossed Thumbs Up
Post #299645 18th Dec 2014 12:14pm
At least it's back for the cold weather and christmas👍 There is nothing that can't be fixed with a hammer😜😜
Post #299695 18th Dec 2014 6:34pm
pld118
And driving like a tight drum! Velvet!!
Some things are worth the wait...
Post #299720 18th Dec 2014 8:27pm
Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #299876 19th Dec 2014 5:56pm
EmiratesA380
United Kingdom 2019 Range Rover SVAutobiography 5.0 SC V8 Aintree Green
Hi pld118
Just read your article you started on page 1 - I had the same problem on on of my 2011 L322 TDV8.
Oil all over the sump pan and down the engine block - had noticed it for a week
Took it to MD and thought it might be expensive - turned out its a common fault and very easy to fix
The cause was one of the injectors on the left bank just needed tightening up - was a 2 mins fix
Hope this helps some one reading this Thumbs Up
Post #307918 25th Jan 2015 7:36pm
pld118
Now being told that after initial inspection by another workshop they might have identified at least two leaks, the main oil leak being from the front of the engine, possibly behind the timing cover. For that, they need to remove the drive belt, pulleys and timing cover. They say once all that has been removed hopefully they can pinpoint where the engine oil leak is coming from.
They say a potential second leak seems to be coming from the transmission/diff area. They suggest repairing the engine oil leak first, completely cleaning off all evidence of an oil leak, and then rechecking to clarify secondary leak sources.
Post #323027 18th Apr 2015 7:06am
pld118
Just realised this thread has been ongoing for 7 months to the day Shocked Yawn
Unbelievable.
Post #323091 18th Apr 2015 2:18pm
Page 3 of 4 <1234>
