Home > Maintenance & Mods (L322) > TD6 Coolant change
ahebron
New Zealand
TD6 Coolant change
Evening
I have spent 30 minutes searching but can not find the info I am after.
It is coolant change week here and tonight I have done the Mini One, tomorrow I want to do the FF.
What is the best way to drain, flush and refill the TD6 cooling system?
I have the correct spec antifreeze in the shed.
After the FF I will change the ccolant on her BMW F650 GS, that will be fun.
Thanks
Adrian VW Amarok 2014 Highline auto
Post #292869 14th Nov 2014 9:09am
ahebron
New Zealand
Got it sorted
After trawling the net I finally found a non NAS spec copy of Rave Service.
Post #293101 15th Nov 2014 1:06am
you didnt have to trawl the net for that WM, a link is in our wiki... ... - .- -.
Post #293121 15th Nov 2014 8:28am
ahebron
New Zealand
Hi Stan
In the following from the Wiki
download and repair video links
2002-2006 workshop manual ..RAVE
2006-2010 workshop manual
2002-2006 workshop manual RAVE NAS version
IIDTool user manaul 2002-2005
IIDTool user manaul 2006-2009
rsw solutions repair videos
powerfuluk
microcat online link 1
microcat online link 2
online workshop manual
pdf landrover manuals-link
2002/2005 off road navigation manual
The '2002-2006 workshop manual Rave' is the systems description and operation manual not the service manual
The online workshop manual link takes you to NAS links for L322 which doesnt fully cover TD6.
PDF Landrover Manuals link again has systems description and operation manual not the service manual
You need the service manual not System description and operstion to find the coolant flush info.
I had the full set of Rave on my old laptop but when I updated I lost them and didnt bother to track down a replacement till today when I needed it.
Unfortunatley I didnt pay attention to where I found it.
Post #293124 15th Nov 2014 9:06am
i stand corrected Thumbs Up ... - .- -.
Post #293126 15th Nov 2014 9:33am
ahebron
New Zealand
Thats very formal of you.
I was sitting whilst I corrected you Wink
Anyone with a link to the service manual that can be put up on wiki?
Post #293127 15th Nov 2014 9:35am
Bloke
Scotland 2009 Range Rover Vogue TDV8 Buckingham Blue
Excellent post and just what I was looking for. Thanks OP. Thumbs Up
Post #516492 25th May 2019 4:37pm
ur20v
A Trap
After you drain the radiator run the engine for a minute it will expel some coolant
Post #516494 25th May 2019 4:49pm
Bloke
Thanks dude, will do. On checking 5L of Comma G48 (Green) Coolant is £20 trade from Halfords. Will get that into stock.
Post #516495 25th May 2019 4:54pm
Bloke
Replaced coolant last night. Undid by hand the system drain located at the bottom RHS of the radiator, removed expansion tank screw cap and bleeder screw from EGR heater and allowed to fully drain. Did run engine for a minute to try and get all the old coolant out. Checked old coolant and my tester was showing it was around 15% strength. I then ran the garden hose through the expansion tank and ran that for a few minutes. It ran clear so not much if any corrosion present which is good. Thumbs Up
Replaced with G48 at 40% strength and used distilled water. Ner Ner Kept filling until the expansion tank and radiator top hose were full with the engine running and then bled the system using the EGR bleeder and then took it for a 5 mile drive while checking the heater blew hold N cold and then topped up again and bled to the correct level before closing the bonnet and walking away knowing the motor is protected and water tight. Thumbs Up
Post #517779 8th Jun 2019 12:50pm
RAVE with TD6 here .
Post #517786 8th Jun 2019 1:45pm
